20 Most Recent Olevia 227-S11 27 in. LCD TV Questions & Answers
Check these codes: 11144, 11240, 11331
programmmming TVTV control
The Comcast DTA remote control is preprogrammed at the factory to operate the DTA receiver. The Comcast DTA remote also contains a universal TV library to allow you to control the Power and Volume of your TV.
1. Turn on the TV
NOTE: Please read steps 2 to 4 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2.
2. Press and hold Setup until the Red Light blinks twice, then release Setup.
3. Locate the code for your device in Manufacturer's Codes on the back of this user guide. Brands are listed in alphabetical order with the most popular codes listed first.
4. Enter the first five-digit code for your TV. If you perform this procedure correctly, the Red Light will blink twice
NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code.
5. Aim the remote control at your TV and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 4, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code.
Olevia 227-S11... | Answered on Jul 02, 2016
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Olevia 227-S11... | Answered on Feb 26, 2016
Easiest place to start is the cables and connections. You should be able to get a reaction from the monitor by jiggling them. If you do see the problem go in and out by doing this then replace the cable. If not the cable then you are looking at the video board.
Olevia 227-S11... | Answered on Feb 15, 2015
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Olevia 227-S11... | Answered on Sep 03, 2014
Check its input connection for any loose contact. Make sure that the external antena has been connected to the proper input socket to the TV. If all are found OK, the tuner to your set is faulty. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Olevia 227-S11... | Answered on Aug 09, 2014
Main broad fault. Contact the authorized service center.
Electro help
Olevia 227-S11... | Answered on Jul 11, 2014
T'Con board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Olevia 227-S11... | Answered on Jul 10, 2014
There is no such facilty to any TVs. When you plug in the head-phone pin into head-phone socket, the internal speakers will cut off, and audio will be only via headphones, and vice versa.
Olevia 227-S11... | Answered on Dec 25, 2013
You may use a wireless system. WalMart has wireless sets from $18 and up. Naturally the higher the price the better the quality. If you are near a RadioShack they too, have a variety to select from. They use Recahrgable baterys.
Olevia 227-S11 27 in. LCD TV Logo
110 questions posted
Top Olevia Televison & Video Experts
CoppellTVRepair.com
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Olevia Televison & Video
Most Popular Question
video quit but audio good
  • Televison & Video
