20 Most Recent SVA-USA 42 in. LCD TV Questions & Answers
My dad smashed our remote [Dont ask...] to our SVA
almmost all tv's have a manual power button. look around the perimeter of the tv, sides, etc.
4/6/2009 2:01:12 AM • SVA-USA 42 in.... • Answered on Apr 06, 2009
How to program ditagal channels
Switch to Air, or ASTC in Menu, re-scan. If it's cable, switch to cable, re-scan.
12/4/2020 7:38:20 AM • SVA-USA... • Answered on Dec 04, 2020
0answers
Tv error message
Be the first to answer 1/1/2014 3:48:54 AM • SVA-USA... • Posted on Jan 01, 2014Be the first to answer
Black square in the middle of my picture
Closed caption function is On. Turn it OFF.
4/13/2013 6:25:59 PM • SVA-USA... • Answered on Apr 13, 2013
I have a dark part on tha screen
If it is a burn our then the panel is kaput, otherwise, it must be the inverter.
1/16/2013 4:28:55 AM • SVA-USA... • Answered on Jan 16, 2013
We understand that your problem
some universal remotes are used only tv play.they did not open menu .so you bought original remote and solve your problem. thank you.
10/11/2010 8:06:53 PM • SVA-USA... • Answered on Oct 11, 2010
I have a small sva
With remote access the user menu and then Turn off the ' Closed Caption ' feature.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
6/16/2010 5:31:49 PM • SVA-USA... • Answered on Jun 16, 2010
I need a manual for my polariod TLAC 02612
I don't have the capability to provide you with a manual for your specific Polariod TLAC 02612 model. However, you can try the following steps to set up your Firestick without the remote:
  1. Download the Fire TV app on your smartphone or tablet from the app store.
  2. Ensure that your Firestick and smartphone or tablet are connected to the same Wi-Fi network.
  3. Open the Fire TV app and select your Firestick device from the list of available devices.
  4. Follow the on-screen instructions to complete the setup process.
Alternatively, you can try using a universal remote that supports Firestick, or purchase a replacement remote for your Polariod TLAC 02612 model.Also please note http://surl.li/fuejq
3/26/2023 5:05:17 AM • Televison &... • Answered 34 minutes ago
New astron 5277 menu button does not work? Might be me doing it wrong?
As an AI language model, I do not have access to specific information about the New astron 5277 or its menu button. However, if you are having difficulty getting the menu button to work, there are a few things you can try:
  1. Make sure you are pressing the button correctly: Depending on the watch model, some buttons may require a longer or shorter press to activate. Check the user manual or manufacturer's website for specific instructions.
  2. Check the battery level: If the battery is low, the watch may not function properly. Make sure the battery is fully charged or replace it if necessary.
  3. Reset the watch: Sometimes, resetting the watch can help fix any software issues that may be causing the menu button to malfunction. Check the user manual or manufacturer's website for instructions on how to reset the watch.
  4. Contact the manufacturer or a certified repair center: If the above steps do not work, it may be best to contact the manufacturer or a certified repair center for assistance. They may be able to help diagnose the problem and provide a solution.Also please note http://surl.li/fuejq
3/26/2023 4:06:45 AM • Televison &... • Answered 2 hours ago
2answers
The source does not oscillate
I think language is a problem here. Get a flashlight and shine it at the screen. Do you see a picture? If you do, the back light has failed. ALL question need FULL 'make model (what it is)' please. Replies should be below the person you are Commenting to, not is the 'Ask for More Information' area above.
3/25/2023 11:05:12 PM • Televison &... • Answered 7 hours ago
2answers
Got sound but no picture how come?
That's a good question, how come? No way I can help without the model and make
3/25/2023 7:00:13 PM • Televison &... • Answered 11 hours ago
2answers
How do I fix my black screen lcd led Telefunken tv
If you are experiencing a black screen on your Telefunken TV, but can hear the audio, there are a few steps you can take to try and fix the issue:
  1. Check your TV's connections: Ensure that all cables are connected properly and firmly. Make sure that the HDMI, AV, or other cables are not damaged.
  2. Check the power supply: Make sure that your TV is properly plugged into an outlet and that the outlet is working properly.
  3. Try resetting your TV: Unplug your TV from the power outlet for a few minutes, then plug it back in and try turning it on again.
  4. Check the TV settings: If you are not getting a picture, it's possible that the settings on your TV are not set up correctly. Check your TV's settings, especially the input source, and make sure it's set to the correct input.
  5. Try updating your TV software: If your TV's firmware is out of date, it could cause issues with the picture. Check if there is a firmware update available for your TV model and follow the instructions to update it.
If none of these steps work, you may need to contact a professional TV repair service or the manufacturer's customer support for further assistance.
3/25/2023 1:36:11 PM • Televison &... • Answered 16 hours ago
2answers
The capacitor for a washer (Siemens WM2030)
The details are printed on the capacitor.
3/25/2023 1:33:54 PM • Televison &... • Answered 16 hours ago
2answers
Philips 14pt1365 01
Hi, I would first download the manual for this tv. Try searching online for it. Then read to see what it says. I believe you may have to press and hold two buttons together to get the menu to appear.
3/25/2023 12:24:08 PM • Televison &... • Answered 17 hours ago
3answers
How do I set up mobile hotspot on my ECCO tv
You can't. It is a receiver, not a transmitter and not a cellphone.
3/25/2023 8:34:02 AM • Televison &... • Answered 21 hours ago
Code for Fukuda FLED400SD
3/24/2023 5:00:48 PM • Televison &... • Answered Yesterday
I need to code my Ecco LCD TV. How could I do?
You need to code your television with what? Or do you mean you want a Universal Remote Code for it? Google Ecco television remote codes. ..
3/24/2023 4:33:07 PM • Televison &... • Answered Yesterday
SVA-USA  42 in. LCD TV Logo
2 questions posted
Top SVA-USA Televison & Video Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a SVA-USA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • SVA-USA Televison & Video
Most Popular Question
need new circit borad
  • Televison & Video
