20 Most Recent Soyo 26 in. LCD TV Questions & Answers
check its remote there would be a zoom button on it. with wish you can zoom the image. every time you press that button the screen will change like X2,X3,X1/2 etc. Select the normal mode.
http://electro-medical.blogspot.com/
Soyo 26 in. LCD... | Answered on Nov 11, 2015
The main board is having an issue thats why the inputs wont switch.
Soyo 26 in. LCD... | Answered on Apr 05, 2013
hello gig..... the stand is definitely removable. on the back of the tv look for holes that contain phillips head screws. usually there are between 2 and 4 screws deep in those holes. Use a #2 phillips head screw driver and insert it into one of the holes. turn the screw driver counter clockwise and the screw will come out. Joe
Soyo 26 in. LCD... | Answered on Jun 06, 2011
Hi, well the failure of remotes is very very common, often it is a simple thing, such as a broken battery connection, or the IR diode has a broken join, or there is moisture behind the keypad... all of these will stop the remote. It may pay to have a check over and see if there is anything obvious.. Also make sure the batteries are OK, I have had duds...
If you cannot get it working again, you have a couple of options, first is to contact the manufacturer and obtain a new original one,or obtain a "Universal remote" these units can control many many differing units by inputting a code for the desired one. If obtaining a UR make sure it specifically states that it will work with your exact make model set.
Soyo 26 in. LCD... | Answered on Feb 10, 2011
call the manufacterer.
Soyo 26 in. LCD... | Answered on Jan 11, 2011
Soyo tv's use Samsung chips so you must test every Samsung code from the manual of your remote. If none of them work then your remote is incompatible to this tv, you will have to use another.
Soyo 26 in. LCD... | Answered on Dec 05, 2010
If you had sparks it is dead, but just to be sure unplugg it for a few hours and try one last time
Soyo 26 in. LCD... | Answered on Jul 15, 2009
check input or source then make sure in audio set up speakers on
Soyo Televison &... | Answered on Jan 06, 2020
That means there are no more updates for that TV. You might want to get a newer TV.
Soyo Televison &... | Answered on Jul 11, 2019
Go to home setting on remote. Go to audio settings on tv. Adjust sound from there down to suitable level.
Soyo Televison &... | Answered on Feb 01, 2019
Fixya is unable to determine sources for wall brackets applicable to your Soyo TV.
Soyo Televison &... | Answered on Mar 25, 2018
Soyo  26 in. LCD TV Logo
Popular Tags
15 questions posted
Top Soyo Televison & Video Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Soyo Televison & Video
Most Popular Question
soyo tv won 39 t change between inputs
  • Televison & Video
