20 Most Recent Samsung HL-R6167W TV Questions & Answers
So don't. Just retire the set and move on with a newer cheaper better set with warranty.
Samsung... | Answered on Sep 13, 2017
Highly likely that the sound was coming from the bearing in the color wheel assembly. When the bearing fails, the color wheel cannot spin at the correct speed, and because the speed is measured by the control board, the TV will shut down.
If you can handle a screwdriver - entire color wheel assembly can be replaced for about $100 and 30 minutes of your time.
Samsung... | Answered on Oct 18, 2013
YOUR COLOUR WHEEL OR ONE OF YOUR COOLING FANS IS DEFECTIVE
Samsung... | Answered on Mar 28, 2011
probable cap problem on the power supply
Samsung... | Answered on Jul 19, 2010
What exactly do you mean by "they look like they have sun burn". Can I have an image so that I can help you access the service menu and also which setting has to be adjusted.
Sai.
Samsung... | Answered on May 23, 2010
sounds like you need a new lamp
Samsung... | Answered on Jul 15, 2009
Normally a sign of overheating. Vacuum all the grille holes around the case. Also from Samsung
www.samsung.com > troubleshooting > TSG01108742
When your TV is turning off and on continuously, unplug it and plug it back in. Additionally, try updating the software if the TV stays on long enough between ...
Samsung... | Answered 10 hours ago
According to the analysis of fault performance, it is likely to be caused by the action of protection circuit
If you need tv parts ,you can link to https://www.abctay.com
Samsung... | Answered on Oct 16, 2020
You need to use the Amazon start page on your TV. It will probably give you a new code. Go to your computer Amazon.com/activate
you should be able to enter the six letter code to start your subscription. You should have Amazon Prime to use this feature on your TV.
Samsung... | Answered on Oct 15, 2020
try checking audio cables if ok audio settings if ok try external speaker if able
Samsung... | Answered on Oct 10, 2020
bad capacitors on power board
It might and no harm in trying but generally if something doesn't work as it should there is probably a fault and it is better to ask for help from someone whose job it is - perhaps your internet service provider has a technical hotline and I expect Samsung has...
Samsung... | Answered on Oct 04, 2020
Samsung HL-R6167W TV Logo
10 questions posted
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
View Most Popular
  • Samsung Televison & Video
Most Popular Question
samsung 61 inch dlp tv started
  • Televison & Video
