20 Most Recent
Seiko Diver's Watch Questions & Answers
Adjust expandable watch bands- Timex watch
Most expandable watch bands aren't sizable. IF it is sizable you will be able to tell when you stretch the bracelet out. If it looks like you can unlatch the links when you stretch it out then you might be in luck, but like I said, most are not sizable.
Seiko flightmaster fitted new battery watch wont
Most likely the watch was damaged when the battery was installed. Quartz watches have fragile parts in them. The coils for instance are made of wire thinner than the hair on your head. It takes almost nothing to damage these wires and the coil. Dirt is a big problem. Since a quartz watch has no force behind the gear train the smallest particle of dirt can stop a quartz watch.
Either your watch will need a cleaning or damaged parts will need replacing.
A qualified watchmaker can do this work and get your watch back in working order for you.
Hope this helps,
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Seiko Watch band Adjustment
hi. you have to push or hammer the pin out in the direction showen by the arrow, so the arrow is dis-assembly direction.
How can I turn off the alarm on my Seiko quartz alarm
TO CANCEL THE ALARM TIME YOU HAVE SET ;
1.Pull out the crown to the first click, and press and hold button “B” until the alarm hands stop to indicate the current time.
2. Push the crown back in to the normal position.
