20 Most Recent
Pioneer PDP-506XDE 50 in. Plasma TV Questions & Answers
Tv on no picture
The Power to the video/luminance is missing or The pc video/luminance board is defective needs repair.The Power supply Module provides the voltage to the video/Luminance board.
11/3/2012 8:40:53 PM •
Pioneer...
Answered
on Nov 03, 2012
Hi, My Pioneer PDP 506XDE made a loud
The screen has broken, probably a stress crack waiting to happen from the day the plasma panel was manufactured. It will cost less to replace the TV completely than to have a replacement 50" screen fitted. In the six years or so since your tv was manufactured the screen technology has evolved significantly, fitting a new panel may not even be possible without other major component changes.
The new tv will have a new warranty, but just fitting a new screen will typically get you a maximum 90 day warranty.
7/1/2011 7:22:26 AM •
Pioneer...
Answered
on Jul 01, 2011
Pioneer dvr-220 randomly turns off
There might be a connection that could be loose here to have your TV be turning off or there is a problem with the TV's power supply or a Tcon board problem or the power cord might be bad.
1/30/2023 7:07:46 AM •
Pioneer...
Answered
on Jan 30, 2023
Front display not working on Pioneer BDP-65FD DVD player
The issue you're experiencing with the front display not working on your Pioneer BDP-65FD DVD player could be caused by a few different things. Here are some things you can try to fix the problem:
- Check to make sure the power cable is securely plugged into the player and the outlet.
- Try a different power outlet or power source.
- Check the power switch on the back of the player to make sure it is turned on.
- Check the brightness settings on the player to make sure they are not turned down too low.
- Check the contrast settings on the player to make sure they are not turned down too low.
- Inspect the display panel for any physical damage, like a crack or broken wire.
- If the above steps do not resolve the issue, it may be best to take the player to a professional technician or contact the manufacturer for further assistance or service.
It is important to note that, the above steps are general troubleshooting steps, and the actual problem can be caused by different things, so it is best to consult a service manual for your specific Pioneer BDP-65FD DVD player or contact the manufacturer for more detailed and accurate information.
1/23/2023 12:45:29 PM •
Pioneer...
Answered
on Jan 23, 2023
My Pioneer 5020 unit displays sould level but not picture
please double check that all of the inputs for the tv are placed correctly. Then, you can remove any accessories (ie video game consoles) before power cycling your tv.
Otherwise, you can perform a channel scan next before factory resetting your tv.
Thank you.
11/27/2022 9:22:34 PM •
Pioneer...
Answered
on Nov 27, 2022
I have a pioneer pro 151 TV having issues turning TV on I get a blue light blinking 9 times
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "
brand name" to your device, in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
7/4/2022 11:36:53 PM •
Pioneer...
Answered
on Jul 04, 2022
Pioneer pro 150fd Blinking red light
remote batteries fresh.
USA?
yp.com
call for service TV
end.
bad PSU in TV or shorts to it. top causes of dead.
omg AC power strip dead? connect TV to live wall jack first./
7/4/2022 10:42:41 PM •
Pioneer...
Answered
on Jul 04, 2022
