20 Most Recent Panasonic Viera TX-32LX77 LCD TV Questions & Answers
Unlock regional video restriction
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock and to set the device region free procedure of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
5/2/2017 3:03:41 AM • Panasonic Viera... • Answered on May 02, 2017
Panasonic 32" LCD TV showing almost Black pictures
If a 4 year old 32 inch set likely cheaper to replace than repair it assuming parts are even still available.
8/26/2012 11:35:48 PM • Panasonic Viera... • Answered on Aug 26, 2012
The letters spread verticaly
it sounds like you are describing a smear of some type---check to make sure contrast (picture) is not set way too high.Let me know what you find as I am here to help.
3/14/2012 6:02:39 PM • Panasonic Viera... • Answered on Mar 14, 2012
My remote control doesn't work
Common faults are: some buttons not working, not working at all, corroded battery terminals. Often buttons are sticky because of some dirt accumulated over the years from the sticky little hands of your kids?
The hardest part of repair is often to open the covers. You do not need much experience in electronics repair to repair a remote. Also it is perfectly safe as there is no way to get an electric shock as they work with batteries.
step 1Test your remote with Digital Camera
Check your batteries first or buy new batteries. Once you have good batteries, you can test with a digital camera by pushing the buttons and having camera on and pointing to the infrared led. You should see red light if the remote is working. If no light comes up you obviously have a dead remote but do not despair and procede to the next step
step 2Open the remote control but there is a catch or a few catches.
Remove the screws if any. Sometimes screws may be hidden under a sticker or rubber feet. Often there are no screws at all but just plastic catches hidden so you have to be clever to open it without breaking the case. Use something blunt and flat toclick the covers open. This is often a challenge but should not be too difficult.
step 3Take a picture of every phase so you remember how to re-assemble
Since you are using a digital camera you might as well take pictures of the disassembly so re-assemly will be easier.
step 4Pull everything apart
Did you take a picture of the keyppad layout? Sometimes keypad is just one rubber membrane but sometimes the keys fall away like pieces of a Lego puzzle. And if the buttons are marked with numbers and functions you may struggle to re-assemble them in right order? Use a small plastic takeaway box or similar to store the bits so you don't lose parts.
step 5Inspect the circuit board and repair dry joints
Remotes are often dropped on the floor and may develope dry joints on the battery contacts or circuit board. Inspect the contacts and circuit board under good light with a magnifying lense or if lucky you might have a microscope or just a very good eyesight? Solder all suspicious joints. If there is a sign of water damage you can use methylated spirits and toothbrush to...
step 6Wash the covers and the buttons
Use a smal bowl or similar to wash and contain all the parts so you don't lose bits down the drain. Use old toothbrush to clean all button holes and buttons. Warm water with dishwash liquid does the job. Take particular care with those small buttons and clean them properly. If you can leave the bits to soak overnight they come clean easy. Ultrasonic cleaner would be goo...
step 7Rinse, drain and dry the parts
Rinse with warm water. Use a drainer to contain all the parts without losing small bits down the drain. As extra security use sink plug. Dry with a paper towel. Wipe the buttons dry individually as they may still have some dirt which makes them sticky when in use.
step 8Repair case and re-assemble
If there is damage to the case or buttons you need to do the required repairs. Use hot glue or super glue depending on fault. Let dry overnight if you had to glue something. Re-assemble bits in reverse order and make sure you have the buttons in right place and right way around. Small nicks and dents on plastic cover can often be repaired by heating carefully with a h...
step 9Test with Digital Camera
Test every button as before. Sometimes you have to push two remote buttons simultaneously as with recording buttons . Once you have completed test with your camera you can use the remote.
That's it, I hope you got it going again
8/18/2011 9:51:00 PM • Panasonic Viera... • Answered on Aug 18, 2011
The tv i own: Panasonic TX-32LX77
The TX-32LX77 is an HD TV but only has 720p (1366 x 768) resolution. Full HD is 1080p. (SD is 480i.)
I wish that I had better news.
(It's possible that you won't notice the resolution difference; small screens don't always need the full 1080 lines of pixels from top to bottom of the screen to give a crisp picture.)
5/23/2011 3:38:55 AM • Panasonic Viera... • Answered on May 23, 2011
I have a Panasonic Viera tx l37g20b and i am
Just select the input button on the set, or the remote until the input your on is selected.
3/20/2011 9:34:15 PM • Panasonic Viera... • Answered on Mar 20, 2011
2answers
What board should I change
Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
10/5/2021 11:51:02 AM • Panasonic VIERA... • Answered on Oct 05, 2021
I have a Panasonic Viera TV, but whenever I press aspect on the remote nothing happens.
Could be a bad remote, that button isn't responding
8/22/2021 1:01:06 PM • Panasonic VIERA... • Answered on Aug 22, 2021
Panasonic Viera tc-p65s2 - 7 blinks, won't turn on
I had the same problem with my Viera. if you disconnect the power and ribbon cable from the YSUS board (check youtube for how), the light led will blink 6 times, indicating the YSUS is bad. Check ebay for TNPA5175 board (about $115-160). The pop is one of the DG402RP chips burnout. These are about $4, but only available from China. If you can wait a month for delivery, you can solder the new one to replace the bad one. You may want to purchase several in case more are bad or it happens again.
4/14/2018 8:10:48 AM • Panasonic VIERA... • Answered on Apr 14, 2018
I need to program a Rogers digitial box to my viera t.v.
That probably won't work. You'll have that problem until you get a new TV.
2/13/2018 12:37:40 AM • Panasonic VIERA... • Answered on Feb 13, 2018
2answers
Panasonic VIERA Flat Panel Televisions. Won't turn on. Made one popping sound. Now smoking.
I would say that's pretty much had it ,if there's smoke coming from the back something has burnt out I would take it to a TV specialist to see if it can be repaired Nick
2/3/2018 2:11:06 PM • Panasonic VIERA... • Answered on Feb 03, 2018
Panasonic Viera TX-32LX77 LCD TV Logo
Popular Tags
13 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
VIERA Panasonic
  • VIERA Panasonic
Most Popular Question
unlock regional video restriction
  • Televison & Video
