20 Most Recent
Fujitsu 50 in. Plasma TV Questions & Answers
I have a Fijitsu 50
OK ~ try this... Connect a makeshift antenna to your Antenna proper connection/connector.
Almost anything somewhat large, flat and is metal should work OK... Even a length of old lamp cord may work too! Hopefully you are in range of at least ONE standard HDTV DIGITAL broadcast transmitter(s) "over the air".
IF your audio is now OK suspect that CABLE BOX!
And how about your DVD player? Is your audio and video good using it?
Anthony
Fujitsu 50 inch TV has sound but no picture
Visit the site named 'Electro-help' for
more details. Click this link. View it in
'Flip card' option, which can be selected from the drop down box
menu by the [Sidebar] tag, at the top left corner of the display
window. It will make search easy. There
are more than 900 posts to different brand TVs now
About Fujitsu P50XHA58EBb to fix the power board
I see so many here with no sound/nopicture issues:ISSUES: 1. IF sound main fuse/s are good.2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.3. almost all these sets the troubleshooting involves
checking voltages on the main power board to narrow down theproblem.4. Be safe and if you do not know what you are doing don't open the set.Answers to issues:1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
