20 Most Recent Sharp Aquos LC-37D43U 37 in. LCD HDTV Questions & Answers
Why won't it turn on?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
12/2/2015 11:06:08 AM • Sharp Aquos... • Answered on Dec 02, 2015
Nesecito codigos de aparato de dish network
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
11/6/2015 4:39:07 AM • Sharp Aquos... • Answered on Nov 06, 2015
I have a Sharp Aquos LC-37d43u and when I turn the power on the picture and input show up for a second then the whole screen goes black. Any thoughts?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
9/23/2015 5:16:19 PM • Sharp Aquos... • Answered on Sep 23, 2015
I need a replacement pedestal/stand
TV Parts Universal TV Stands DLP Chips ShopJimmy You can get a universal stand from here.
12/31/2014 6:08:02 AM • Sharp Aquos... • Answered on Dec 31, 2014
I need Aquos LC-37D43U firmware
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
4/6/2014 4:13:23 PM • Sharp Aquos... • Answered on Apr 06, 2014
0answers
0answers
Hi i have a sharp aquos lc-37d43u tv and I can't get it to connect to my computer .I tried HDMI and VGA but I just don't seems to understand how to make it work ;( Please HELP
prob with sansui sty 0330 LCD TV hi,i have a sansui sty 0330 tv and the screen is flashing 1 second flash, 1 second good, then 1 second flash, 1 second good is going like this contineously
12/18/2013 5:31:43 PM • Sharp Aquos... • Answered on Dec 18, 2013
0answers
My LC-37d43U won't turn on, no lights, no
Open fuse on power supply board, or the power supply is dead, or there is no voltage coming out of the receptical out of the wall, You can hget a new power supply at b www.partstore.com take care.
11/3/2011 7:21:01 PM • Sharp Aquos... • Answered on Nov 03, 2011
I have a LC-37D43U. The
It seems back light turns Off for some reason that is why you do not see picture any more in tv screen, lcd tv requires back light to present its image in lcd screen.
Possible causes for that problem is power supply board failure or back light inverter board got defective and need to be replaced.
This tv has two back light inverter boards and available in shopjimmy.com Power supply is also available. Board swapping is only option to solve the problem in lcd tv.
Hope these info will help you.
Thanks.
8/6/2011 10:02:30 AM • Sharp Aquos... • Answered on Aug 06, 2011
I have a sharp aquos
Normally this is indicative of a faulty power supply circuit inside your TV.
The easiest way to test this is to remove the rear access panel on the TV and replace the power supply circuit board with a new one.
You can find a replacement circuit board on Ebay by searching for your TV's model number.
Here is a link to one currently available for about $100 plus shipping:
http://cgi.ebay.com/DPS-178APA-Power-Board-Power-Supply-Sharp-LC-37D43U-/260814504762?pt=LH_DefaultDomain_2&hash=item3cb9c1833a
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
The repair / replacement procedure is not extremely difficult if you have some basic electrical safety knowledge and some basic electronics / mechanical repair skills.
You will need to unplug the power cord from the unit, lay the TV screen side down on something soft and flat like a bed, and then remove the rear access panel or the entire rear cover as required in order to access the circuit boards inside.
When you remove the rear cover and access the circuit boards inside, just check the part number that is printed right on your power supply circuit board itself and confirm that it exactly matches the one provided in the Ebay listing.
Then unclip and remove the various electrical wire connectors leading to the power supply circuit board. Then remove the screws securing the circuit board to the TV frame and then remove the power supply circuit board. Be sure to avoid touching any large capacitors on the circuit board which can retain a nasty charge even after the unit is unplugged.
Then just screw in the new circuit board and connect all the wire bundles to their appropriate connectors on the new circuit board and then replace the rear cover. Then plug in the power cord and test.
One other thing you can check is to see if there is a fuse fitted on your set.
Some models will have a fuse holder compartment accessible from the rear of the set right where the power cord enters the enclosure. If your set does not have one of these, then the fuse may be located directly on the power supply circuit board itself.
Try testing that fuse for continuity with a voltmeter (with the set unplugged of course). If that fuse has failed, then it will test OPEN. If you are lucky, you may then just need to buy an exact replacement fuse and then install / solder that into place to correct the problem
I hope that was helpful to you, good luck.
Joe.
7/17/2011 12:36:05 PM • Sharp Aquos... • Answered on Jul 17, 2011
Have not got base
Tries websites like Amazon.com,Ebay.com to buy a used or new tv base stand.Cost might run u like $25-30 for a used one and $40-50 for a new one.
6/11/2011 9:15:22 AM • Sharp Aquos... • Answered on Jun 11, 2011
TV wont turn on. No sound or backlight. The OPC
There is a problem with the standby section of the power supply. A flashing standby light indicate an overload which is caused by a shorted semiconductor in that circuit. It's fairly simple for a technician and should not cost much. You can't do that yourself it is electronic takes a long time to grasp.
6/4/2011 2:39:21 AM • Sharp Aquos... • Answered on Jun 04, 2011
My sharp lc37d43u remote wont turn tv off or on
What was the tv problems before u change the power supply board?Give me the previous problems,so i can tries to retraced the cause and give u a solution to fix the tv.
10/20/2010 4:58:10 AM • Sharp Aquos... • Answered on Oct 20, 2010
Sharp Aquos LC-37D43U 37 in. LCD HDTV Logo
35 questions posted
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
Aquos Sharp
  • Aquos Sharp
Most Popular Question
lc 37d43u won 39 t turn no lights no
  • Televison & Video
