20 Most Recent Samsung PS50Q91HD 50 in. HD-Ready Plasma TV Questions & Answers
I would not advise you to buy a non working TV specially when Plasma is moving out and the new technologies with 3D- LED is around bringing the prices down.
Also the cost is not the factor but if there is fault on the mother board then you are stuck and would have wasted money on a junk. So please do not commit UNLESS you can source a power supply unit - SMPS unit - and make sure that it is the ONLY issue. Let the TV work and then after seeing a good picture you can take tbhe risk... but the cost is also important and must be checked out.
Samsung... | Answered on Aug 30, 2011
Use you HDMI Input, depending the source your using has HDMI output resolution is 1080p or 1080i
Samsung... | Answered on Jan 17, 2011
The problem is from a capacitor inside the television, it is actually weak and as soon as it is getting heated, it starts to malfunction which results in the cracking up and dropping out on the screen you are noticing.
All you have to do is to open up the back cover of the television you will see some compartments with metal sheets that has tiny holes, unscrew them, they are covering the main board of the television.
After opening up the compartments, test the capacitors and check for the shaky one and replace it. Also any one you detect that it has swollen, replace it. couple the television back together and plug it to a power source and turn it on, and your television will be okay once again.
Take care
Samsung... | Answered on Jul 09, 2010
no power to tv light blinks on and off
Samsung... | Answered on Feb 27, 2010
Power supply may have been damaged but due to a lightning storm/electrical storm, most of the other panels will also be damaged.
Samsung... | Answered 2 days ago
If the power supply board is confirmed as being wired for either voltage. Sometimes there is no alternate connection to a board so marked.
Samsung... | Answered 3 days ago
Normally a sign of overheating. Vacuum all the grille holes around the case. Also from Samsung
www.samsung.com > troubleshooting > TSG01108742
When your TV is turning off and on continuously, unplug it and plug it back in. Additionally, try updating the software if the TV stays on long enough between ...
Samsung... | Answered on Oct 21, 2020
According to the analysis of fault performance, it is likely to be caused by the action of protection circuit
If you need tv parts ,you can link to https://www.abctay.com
Samsung... | Answered on Oct 16, 2020
You need to use the Amazon start page on your TV. It will probably give you a new code. Go to your computer Amazon.com/activate
you should be able to enter the six letter code to start your subscription. You should have Amazon Prime to use this feature on your TV.
Samsung... | Answered on Oct 15, 2020
try checking audio cables if ok audio settings if ok try external speaker if able
Samsung... | Answered on Oct 10, 2020
bad capacitors on power board
It might and no harm in trying but generally if something doesn't work as it should there is probably a fault and it is better to ask for help from someone whose job it is - perhaps your internet service provider has a technical hotline and I expect Samsung has...
Samsung... | Answered on Oct 04, 2020
Samsung PS50Q91HD 50 in. HD-Ready Plasma TV Logo
12 questions posted
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
View Most Popular
  • Samsung Televison & Video
Most Popular Question
used
  • Televison & Video
