20 Most Recent
Acer 24 in. LCD TV Questions & Answers
SCREEN GOES DARK AFTER 5
I love that monitor. I have two in use right now.
The symptoms sound like a burning out lamp. The lamp that powers the light of behind the lcd might be going bad. They're a costly fix but replacements can be made, although not advised.
Acer PD116Pd Projector no powerup .
Please start by switching the outlet that you use to power your projector. If you're not currently plugging the projector into an outlet but using a power strip, you can test that the power strip is still functioning by using it with other items. Thank you.
What is my remote control number for Acer brand At3235b TV?
Statistical Process Control TrainingAll Acer TV models use the universal Remote Control code NEC 18E7, which most of universal Remote Controls can use. We recommend using the search function, available on most universal remote controls, to find the compatible code for your Acer TV.
Have blue line across my acer one tablet Oly a month old why is this happening
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
