20 Most Recent Windchaser PACR10000 Portable Air Conditioner Questions & Answers
Under normal conditions, refrigerant or freon need not be recharged or replenished. Refrigerant is contained in a "closed loop" that consists of a compressor, expansion valve, evaporator coil and condenser coil. If a leak developes as a result of damage to any of these components, the refrigerant will escape as it is under pressure. The leak will need to be located and repaired before refrigerant can be returned to the system. An unsufficent refrigerant level is always an indication of a leaking system, but; an A/C unit that fails to cool the air is not always a sign of a low refrigerant level.
Windchaser... | Answered on Aug 26, 2011
Go to wind chaser website under PACR10000 and download the manual.
Windchaser... | Answered on Aug 05, 2011
All portable or window ac units are mounted or standing with the back lower housing at a slope
so that the condensed water buildup from the evaporator can drain into a tray or thru a tube out
the back of the unit, depending on what kind of unit you have you may have to take it apart and
make sure the drain for the condensed water is not blocked. some times these units are not
installed correctly, they will not drain properly and standing water with time will turn to rust and
clog up the tube where it needs to flow from the ac unit. good luck!
Windchaser... | Answered on Jul 31, 2011
Most electronic devices have power to the main control board when the unit is plugged in regardless of the switch being on or off. If that is the case and no other issues exist, it is nothing to be concerned about.
Windchaser... | Answered on Sep 16, 2020
I didn't see the manual when I searched, although there were other manuals.
I saw the following article that may be of use to you.
https://homesteady.com/how-7511194-operating-instructions-windchaser-pacr10.html
Windchaser... | Answered on Apr 11, 2019
Sorry we do not have parts here, nor do we have any locator service for parts for anything
Windchaser... | Answered on Mar 10, 2018
Eithee the filter is dirty, coil is dirty, primary pan is dirty or the tube or drain is clogged. It needs a good bath!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Windchaser... | Answered on Jun 25, 2017
Windchaser PACR10000 Portable Air Conditioner Logo
Popular Tags
10 questions posted
Top Windchaser Heating & Cooling Experts
Marvin
Marvin
Dennis Boxerman
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Windchaser Heating & Cooling
Most Popular Question
need recharge coolant once in while
  • Heating & Cooling
