20 Most Recent AEG T58840 Dryer Electric Questions & Answers
If you pull the panels off you should find the tech sheet to help diagnose your machine. But in you case sounds like it need to be taken apart and cleaned and check the limit switches.
AEG T58840 Dryer... • Answered on Dec 04, 2015
Ok I believe your referring to a washer machine. But I would suggest to review user manual, and if all else fails I would call in for service, cause your machine is still under warranty.
What condenser are you talking about, cause it's sound like your talking about a refrigerator.
E51 - Motor power triac short-circuited. E52 - Intervention of motor overheating safety cut-out. E53 - Motor triac "sensing" circuit faulty. E54 - Motor inoperational. Dado
AEG T58840 Dryer... • Answered on Oct 20, 2015
E61 - Insufficient heating (maximum time exceeded) E62 - Power relay to heater unit faulty E63 - Intervention of auto-reset thermostat on the heater unit. 23830107-3rcfyex5vwz3ubyzzwgflfev-1-0.jpg Dado
E61 - Insufficient heating (maximum time exceeded) E62 - Power relay to heater unit faulty E63 - Intervention of auto-reset thermostat on the heater unit. E64 - Heater thermostat. E65 - Fan motor triac faulty. E66 - Fan motor thermal protection. E67 - Triac control faulty. Dado
Your dryer is called smart dryer and in this case should have to generate familiy code E60 (or any of exactly fault code E61,62,63,64,65,66,67) if blowing cold air, as you explain. Means something is wrong with heating phase (drying). So, in this case could be: Heater unit faulty; Wiring faulty; NTC sensor faulty/out of position; Electronic board faulty; Thermostat faulty; and finally fun motor - but considering that it blows cool air I guess that is correct. 24642590-hf2jxxovvq5cn05mugly0fcq-2-0.jpg Dado
AEG T58840 Dryer... • Answered on Oct 16, 2015
There are many things that could be wrong. On most machines there is an electrical diagram somewhere inside or on the back of the cabinet. You can check each item in the heater circuit until you find the faulty item. On most dryers it is the "over heat" fuse link that goes first, but there are MANY other possibilities. First thing.... make certain all switches are in the correct position, not half pressed in or 2 pressed at once. I hope this is helpful.
AEG T58840 Dryer... • Answered on Jul 19, 2014
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
AEG T58840 Dryer... • Answered on Aug 24, 2011
AEG T58840 Dryer Electric Logo
43 questions posted
Top AEG Dryers Experts
Dan Webster
Dan Webster
Pieter Vleeshouwers
Pieter Vleeshouwers
ADMIN Canada
ADMIN Canada
Are you an AEG Dryer Expert? Answer questions, earn points and help others
View Most Popular
AEG Dryers
  • AEG Dryers
Most Popular Question
indest 7kg tumble dryer barrel
  • Dryers
