20 Most Recent Motorola Talkabout T5820 (14 Channels) 2-Way Radio Questions & Answers
Can't get walkie talkies to communicate
if they are both the same model, make sure both the channel and ctcss codes match, as there can be 38 codes per channel, if they dont match u will not be able to communicate between them http://www.motorola.com/mdirect/manuals/T58xx_User_Manual.E.pdf that will show you how hope this helps
5/17/2016 7:40:31 AM • Motorola... • Answered on May 17, 2016
Can i get CB communication
Sorry but the answer is no. Your TalkAbout T5820 is an FM radio operating on FRS frequencies in the UHF range (462-467 MHz). CB radios are AM radios operating between 26.965 -27.405 MHz.
Best regards.
8/16/2011 5:07:59 PM • Motorola... • Answered on Aug 16, 2011
0answers
I lent my Talkabouts to a friend, and her daughter
try Motorola.com or eBay
12/2/2010 3:17:03 PM • Motorola... • Answered on Dec 02, 2010
How to shut off roger beep on motorola mr355r
Here is a link to the user guide. The description is on page two under Talk Confirmation Tones.
http://www.giantintl.com/ContentManage/manuals/Moto/MR355%20User%20Guide%20Updated%20Chart%20FINAL%2004-02-09%20KEM-PK14190-94A.pdf
11/26/2009 4:06:01 AM • Motorola... • Answered on Nov 26, 2009
I can not get the roger beep to turn off on my
We could not immediate locate a user guide for your T5000 radio, however, the T4900 and T5100 radios manuals both indicate the roger beep is turned on/off by holding in the plus (+) button while turning the radio on.
Best regards.
11/16/2009 1:24:21 AM • Motorola... • Answered on Nov 16, 2009
How to turn off
Press and hold the + (plus) button when turning on the radio. Here is a link to the user manual: http://www.giantintl.com/ContentManage/manuals/Moto/T58xx_User_Manual.E.pdf
10/20/2009 11:15:21 AM • Motorola... • Answered on Oct 20, 2009
Need help without an instruction book
Here is a link to the manual: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T58xx_User_Manual_E.pdf
Refer to pg 16 for programming instructions.
9/6/2009 2:51:58 AM • Motorola... • Answered on Sep 06, 2009
Programming Motorola XPR 3500e please?
https://www.google.com/search?q=motorola+xpr+3500e+programming
MOTOTRBO XPR 3000e Series
Motorola Solutions https://www.motorolasolutions.com > portable-radios > x... Integrated Wi-Fi; Over-the-air software updates; Bluetooth® audio; Enhanced audio quality; Channel lock (XPR 3500e only); Improved expandability ...
MOTOROLA XPR 3500e UHF PORTABLE RADIO
Wi-Com Solutions Inc. https://wicom.ca > product > motorola-xpr-3500e-uhf-p... MOTOROLA XPR 3500e UHF PORTABLE RADIO. $1,298.00. With this dynamic evolution of MOTOTRBOâ„¢ digital two-way radios, you're better connected, safer and more . ..Not sure is this is relevant
3/23/2024 5:46:16 AM • Motorola Radio... • Answered on Mar 23, 2024
I have a pair of Motorola MS350 radios. 1 works fine but one does not receive or transmit. I have both radios set up the same.
If your frequency and code are set the same, you have either a battery problem or a radio problem. For a quick battery test, swap the battery pack from the good radio into the one with the problem and see if the problem moves. Then you will know if it is simply the battery. If both settings are identical and the battery swap does not solve the problem, you have a defective radio.
2/12/2024 3:14:21 PM • Motorola Radio... • Answered on Feb 12, 2024
2answers
I need help to dismantle a motorola radius sp10 2 way radio
Remove the battery, slip a small screw driver into the slot at the bottom of the radio between the outer housing and the battery tray, gently pry up. If your radio has a pair of battery contacts on the exterior they will come up with the tray. Be gentle, and do not disturb the Mylar ribbon that runs down the back of the tray. Once the tray is removed, using a frame removal tool (shaped like a squared letter U) you slip the tool in the channels on either side of the radio where you removed the battery tray. Then slide the tool upward until it meets the two plastic ears. The tool will slip under the ears and using your tool you can push the component board out the top of the housing. If your radio has an 8-dip-switch private line board, you may want to watch you do not damage or dislodge it in the process.
2/12/2024 3:05:06 PM • Motorola Radio... • Answered on Feb 12, 2024
Can the Motorola factory replace the battery in the H730 headset?
It is possible to have the battery in your Motorola H730 headset replaced, but it would likely need to be done by a third-party repair service as the battery is not typically user-replaceable. Motorola does not offer an official repair service for the H730 headset, so you may need to find a third-party repair service that specializes in repairing Bluetooth headsets. Be aware that third-party repairs may void any remaining warranty on the device. You can also consider purchasing a new headset if you prefer not to have it repaired.
2/27/2023 5:03:32 AM • Motorola Radio... • Answered on Feb 27, 2023
2answers
I have two older Motorola Walkies Talkabout FR60 wont send or receive and a T5820 with the rubber broken off the antenna is is cost feasible to fix or not
I believe for the FR60 walkie-talkies, if they are not sending or receiving, the issue could be related to the antenna, battery, or internal components. You can try replacing the batteries and/or antennas to see if that resolves the issue. As for the T5820 walkie-talkie, if the rubber on the antenna is broken, it's likely that the antenna itself is also damaged. In this case, you can try replacing the antenna with a new one. Antennas are typically available for purchase online or at electronics stores. In terms of cost, repairing older walkie-talkies like these may not always be cost-effective. If the repairs are extensive or require replacement of major components, it may be more practical to purchase new walkie-talkies instead. Below are options of the options of walkie-talkies you can buy; ir?t=emerald014-20&language=en_us&l=li2&o=1&a=b071kjlcjv
2/24/2023 3:00:37 PM • Motorola Radio... • Answered on Feb 24, 2023
Motorola Talkabouts T5820 and FR60.
Question moved from Televisions. Yes of course. Well made and efficient sets. https://www.google.com/search?q=Motorola+Talkabouts+T5820+repair ..
2/24/2023 5:21:36 AM • Motorola Radio... • Answered on Feb 24, 2023
Anybody know how to reset a Motorola DP4800e radio to its factory settings?
Let me know if you find out lol. Glen
2/5/2023 12:55:13 AM • Motorola Radio... • Answered on Feb 05, 2023
Motorola sliver headset won't power on even when the green lights are solid
There are a few things you can try to troubleshoot this issue with your Motorola Silver headset not powering on:
  1. Make sure that the headset is fully charged by connecting it to the charger for at least 30 minutes.
  2. Check the battery contacts in the headset and charger to ensure that they are clean and free of debris.
  3. Try resetting the headset by holding down the power button for 15 seconds.
  4. Try a different charger or charging cable to see if that resolves the issue.
  5. Make sure that the headset is not in pairing mode.
  6. Check the headset manual for any information regarding troubleshoot, or if there are any specific instructions for turning on the headset.
If none of these steps resolve the issue, it may be a problem with the headset itself and you may need to contact Motorola for further assistance. Please note that the information provided is based on my knowledge cut-off date and it may not be current.
1/27/2023 9:16:15 PM • Motorola Radio... • Answered on Jan 27, 2023
Can you use the Motorola XPR 4550 as a police scanner?
The Motorola XPR 4550 is a two-way radio, not a scanner. Scanners are devices that can listen to a wide range of frequencies, whereas two-way radios are designed for communication between a limited number of specific devices on specific frequencies. However, you can use a scanner to listen to the frequency that the Motorola XPR 4550 is transmitting on.
1/22/2023 4:26:08 AM • Motorola Radio... • Answered on Jan 22, 2023
Motorola XTL5000. encoding is working but decoding is not. If you encode a different tone on another radio it still hears it.
El problema de decodificaci?n de la radio Motorola XTL5000 puede deberse a una configuraci?n incorrecta de la radio. Aseg?rate de que la radio est? configurada correctamente para la codificaci?n y decodificaci?n. Por ejemplo, aseg?rate de que los ajustes de codificaci?n sean los mismos tanto para la codificaci?n como para la decodificaci?n. Tambi?n debes asegurarte de que la radio est? configurada en la misma frecuencia de la otra radio. Si esto no soluciona el problema, prueba la antena para asegurarte de que est? funcionando correctamente. Si la antena est? bien, podr?as necesitar reemplazar la placa de circuito impreso (PCB) del receptor para solucionar el problema.
1/6/2023 1:56:52 AM • Motorola Radio... • Answered on Jan 06, 2023
2answers
Radio Communications - Can you replace the plastic sleeve covering of the Motorola RDM2070d antenna?
they are available on eBay for $6.00 you can look online there are several vendors. google Motorola RDM2070d antenna good luck
12/21/2022 10:34:16 PM • Motorola Radio... • Answered on Dec 21, 2022
Motorola Talkabout T5820 (14 Channels) 2-Way Radio Logo
Popular Tags
9 questions posted
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Radio Communications
Most Popular Question
not get roger beep turn off
  • Radio Communications
