20 Most Recent Motorola Talkabout T6500 (7 Channels) 2-Way Radio Questions & Answers
Take the radios back to a very basic setting with all special features turned off. If the radios have a Qt filter check to see it is turned off, and set your Code to zero (off) on both units. Also, check to see your battery is good in both units.
Motorola... | Answered on Sep 10, 2017
they might be on same channel but ctcss codes will be different
http://www.motorola.com/mdirect/manuals/T6500_usermanual.pdf
hope this helps
Motorola... | Answered on May 17, 2016
Here is a link to the user guide http://shop.giantintl.com/Manuals.asp Choose your model from the page or the pulldown.
Motorola... | Answered on Jan 08, 2015
Here is a link to the user guide for the T6500
You will need to set the frequency and interference eliminator code to match one another on both radios. It would be adviseable to keep any special features such as call alert and Qt filter turned off (zero) until you are confident in adding them into the mix.
Instructions can be found on pages 15-18.
Best regards.
Motorola... | Answered on Jan 30, 2014
You can find a link to the user guide at shop.giantintl.com/Manuals.asp
Best regards.
Motorola... | Answered on Jun 17, 2013
Join the que my friend, MANUALS for these little toys are like hens teeth.
Motorola... | Answered on Mar 10, 2013
No, the TalkAbout family radio service/GMRS radios and the CP100 business radio have no frequencies in common. Sorry.
best regards.
Motorola... | Answered on Jul 13, 2012
It is possible if you have a radio programmed to police or emergency frequencies, or better yet, a scanner. Your local electonrics store should be able to help you with this.
Best regards.
Motorola... | Answered on Jul 10, 2012
Copy of the user manual can be downloaded from this link, just click HERE.
Motorola... | Answered on Apr 19, 2011
Here is a link to the user guide http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf This radio does the basic FRS and some GMRS UHF frequencies. If your other radio is capable of these types of frequencies, you should be able to match the two.
Best regards.
Motorola... | Answered on Jan 26, 2011
It can talk with any radio that operates on the same frequency as it. These are what are commonly reffered to as FRS (family radio service) radios. The name brand does not matter, but the frequency does.
Motorola... | Answered on Jan 25, 2011
The TalkAbout radios are license-free and operate on FRS/GMRS frequencies intended for family use. It is possible using them in a business situation may be outside of the license-free perimeters. You would need to check further on this through a licensing company or the FCC (www.fcc.gov)
Here's a link to the user guide for the T6500. http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf
Here's a link to the Motorola TalkAbout Store: http://www.store.motorola.com/2-Way-Radios-Mobile-Devices-Products/b/2265993011?ie=UTF8&title=2%20Way%20Radios The T6500 is not a current model, but the models shown would talk with it, and work similarly.
Here's a link to another vendor we have had success with http://www.wirelesspro.com/ They show the T6500 on their website for sale.
Best regards.
Motorola... | Answered on Jan 11, 2011
Yes, other TalkAbout radios are compatible with the T6500. Most of this series of radios have the 14 FRS frequencies installed.
Bestr regards.
Motorola... | Answered on Jan 07, 2011
Here is a link to the T6500 user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf
You will need to read about locking the keypad, page 20; also read about call tones and talk confirmation (roger beep) on page 25.
Best regards.
Motorola... | Answered on Nov 12, 2010
Here is a link to the user guide, reference page 22 for instructions on turning iVOX and VOX on or off: http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf (Double check you do not have the lock symbol showing while trying to change programming.)
Also, another phenomenon which can occur is when you unplug a headset or audio device while the radio is still turned on. This can leave the radio partially in VOX mode. You might try plugging in the device with the radio turned off. Then turn the radio on, use the device in VOX mode. Then shut the radio off and remove the device. See if it clears the radio's sense of having a headset plugged in.
A damaged jack can also cause the same problem.
Best regards.
Motorola... | Answered on Nov 06, 2010
We have been able to get some headsets through www.wirelesspro.com; and also the Motorola online store at http://www.store.motorola.com/Headsets-For-2-Way-Radios-Accessories-Products/b/2265980011
Best regards.
Motorola... | Answered on Oct 22, 2010
Just read your message a second time. Is the sound following the release of the PTT button? If so, it is indeed the Roger Beep (aka talk confirmation tone). If holding in the minus button while turning the radio on does not turn it off, there might be something wrong with the radio, such as a one of the other buttons being slighty stuck. Or you have your keypad locked. To unlock the keypad hold the menu button in for 3 seconds until the lock icon disappears.
Another thing which will make a noise during or after transmitting is the low battery beep. You might check your batteries. Old, bad, poorly charged or defective batteries can cause this.
fyi: Some users might think the Call Tones are the Roger Beep.
Lastly, there is a PTT Timeout beep which will occur if you hold the PTT in for more than 60 sec while talking.
Hope one of these items is of help to you.
Best regards.
Motorola... | Answered on Oct 13, 2010
The T6500 is slightly different than many of the other TalkAbout radios where the + (plus) button turns the Roger Beep (aka talk confirmation tone) on or off.
T6500 will turn ON the Roger Beep when turning the radio on with the +, but to shut it OFF you must hold in the - (minus) button while turning the radio on.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf You will find the instructions in detail on page 25.
Best regards.
Motorola Talkabout T6500 (7 Channels) 2-Way Radio Logo
Popular Tags
30 questions posted
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Radio Communications
Most Popular Question
will motorola t6500 39 s or t5300 39 s
  • Radio Communications
