20 Most Recent Estate White-on-White TES325MQ Electric Range Questions & Answers
are you sure u did not mean TCD? Ok check this out
Estate... | Answered on Mar 24, 2014
sorry to hear that your burner has shorted out here is the schematic http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28212705&pkw_=basket&model_id=5132488&NewWindow=1 depending on if it were the big or smaller one would depend on the part number in order to obtain a new one. Here are both just click on them 6 inch Small surface element AP3134976, 8 inch large surface element AP3031500 If you have any further questions message me back if you also needed to replace the receptacle as well Surface burner receptacle AP3030713 . Please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks
Rick
Estate... | Answered on Sep 07, 2011
All bake elements are not the same. The part # for your bake element is #9758519. Hopefully you can find an appliance parts store in your area. Thay are fairly ease to replace. With the oven UNPLUGGED, Remove the two screws holding the element in and there should only be two wires connected to the element.
I hope this helps you. If I can assist you further, please let me know.
Thanks,
Vic
Estate... | Answered on Apr 23, 2011
You seem to have the moxie and electronic test tools so why not try to get a schematic for unit? Appears to be your best bet. You can try a google search for it or try this site which often has electric schematics for appliances. Search Over 2 1 Million Appliance Parts
Estate Kitchen... | Answered on Sep 06, 2017
There should be a metal spring cip ring around the spindle of the knob which keeps it tight around the spindle on the switch. Sounds like its snapped. Compare it with one that works, they should just pull off and push back on, but with a little bit of resistance.
Estate Kitchen... | Answered on Nov 26, 2013
Only one image was posted.
The thermostat and the thermocouple bulb are two separate items.
The thermocouple has a small bulb (like a thermostat) that tells the main burner that the pilot is lit and the main burner valve can open. That bulb always has a tip poking into the flame from above.
The thermostat regulates the flame of the burner to maintain a set temperature by being somewhere around the middle of the oven cavity.
The OP provides the answer here
https://www.fixya.com/support/t29791485-found_answer_question_attach_thermostat
Andrew - Moderator
Kitchen Ranges | Answered 3 days ago
You know you can edit posts? So can I . I edited it for you!
Andrew = Fixya Moderator
You would be looking for a clip that holds it.
https://www.google.com/search?q=vintage+Hardwick+stove.+How+does+the+thermostat+bulb+mount+to+the+pilot+burner
Kitchen Ranges | Answered on Oct 24, 2020
There are video's on YouTube about how to fix propane stoves and on google too.
Kitchen Ranges | Answered on Sep 22, 2020
Resolve Toshiba Error Code f3 f200 0002 normally happens temporarily and a system reset then disappears afterwards. You want to go through a number of possible reasons to find the exact reason for this.
Effective Methods to Overcome Toshiba Error Code f3 f200 0002: Whenever this error appears, you need to go through a number of possible reasons to determine the actual cause. This blog will help you to fix this Toshiba Error Code f3 f200 0002 with the help of step by step solutions. You can also connect with Toshiba Customer Care Service to get to the roots of the error.
Perform a system recovery on the computer to repair this Toshiba Laptop error as easily possible.
Recover your Hard Drive using the following steps:
  • Shut your computer down by clicking on the Start and thus "Shut Down" button.
  • Depress your system's power switch while holding the 0 key pressed.
  • The Toshiba HDD Recovery Utility screen will appear as soon as the computer turns on.
  • When you restore a hard drive to its factory default state, all partition on the hard drive and the data stored within it gets deleted. Make sure to back the important files before performing the restore process.
  • Next, you need to press 1 to restore your hard disk to its original factory default state.
  • An alert message will appear saying "all data will be overwritten and lost during the restore process". Back up the files before proceeding.
  • After that click on Yes option to start the restoration process.
  • You will be notified with a message saying the HDD has been restored.
  • Press any key to restart your Toshiba Laptop.
  • If the 0 key does not start the recovery process, it means that your system does not have an inbuilt recovery option. On such case, use the Toshiba recovery disk that comes with your Toshiba laptop.
Source URL: https://www.toshibasupport365.com/blog/how-to-resolve-toshiba-error-code-f3-f200-0002/
Kitchen Ranges | Answered on Sep 18, 2020
Estate White-on-White TES325MQ Electric Range Logo
9 questions posted
Top Estate Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Andrew Taylor
Andrew Taylor
Are you an Estate Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Estate Kitchen Ranges
Most Popular Question
burner shorted out
  • Kitchen Ranges
