20 Most Recent
MSI GX630-028US Notebook Questions & Answers
Msi computer turns of while playing
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail. A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust. Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
How to turn on wireless
Please check the image.
Your laptop has this touch button to on or off wireless .
Thanks for using FixYa.
My f11 keys doesn't work
i suspect your f11 key does work, try opening a web browser and while it is open press the f11 key if your browser goes full screen the f11 key works just press f11 again to return it to normal. Try pressing and holding the fn key and then press f11 that will switch your wireless on and off
Problem with my MSI GX630-028US Notebook.
We know it is a power problem, there can be a few issues and just guessing because it is not in front of me I can tell you if the machine does not power on with the battery taken out or with the battery in and power plug out. It is either the power supply unit which you changed out or a board issue or the power button is bad. If I was to just guess which is all I can do from this end. If I had a choice to replace the power button or the board I would do the power button first if that does not work then a new or refurbished board is needed. I suggest you take it in to a computer repair place so they can test these items out. John
I cannot find how to
hi there,
Hold the FN key and press F11. That will turn the switch on for the wireless.
Hope this helps, pleas rate if it does. thanks
levibit
I can't turn on my
We ran a typical
Dell inspiron 1545 battery of tests, including games, applications, and a couple other areas. Time constraints limited the amount of testing we could get done before the NDA lift (and it's already a few hours late), but we will be providing a follow-up article with further testing and information. That said, if there are any specific areas that you'd like to see tested, feel free to e-mail me or leave a comment.
Have had overheating problems for
You may have damaged the cpu if it is overheating. The cpu will slow down and then shutdown trying to protect itself. However once it is damaged ie won't run then you need to replace the cpu. The cpu is worth about $120 and then labor to disassemble the laptop.
You also need to clean the cooling system out so this doesn't happen. Thats easy to do using either compressed air or a vacuum. If you don;t then this will just happen again.
I cannot turn on wireless capabilty
Follow these Steps :
1> Go to start
2> Click on RUN
3> Type SERVICES.MSC
4> New Window will appear
5> Go to bottom of the page
6> Select Windows ZERO Configuration
7> If it shows Manual then Right click on this service
8> Go to properties
9> You will get START TAB
10> Click on START
11> Click APPLY and then OK
12 > Select AUTOMATIC where its shows start service MANUAL
Now try to connect with wireless connection
If still its not working then folow these steps .
1> Go to Control Panel
2>Click on Network Connections
3>Right click on Wireless network Connections
4> Click on properties
5>New Window will pop up
6> Select Wireless networks tab
7>Check very first option which says " Use Windows to configure my Wireless Settings
8> click on Apply
9> click OK
now try to connect with wireless
How to reset Bios password on HP QL62 computer
Hi, there is no easy way of doing this, your best bet is to contact MSI Customer support and explain the sittuation.
Manufacturers often put passwords to stop you from altering anything in the bios, because it has been tuned for that pc.
I hope I have helped, but if you need more info, just ask.
http://us.msi.com/index.php?func=service
Hard drive spins, but computer and screen don't boot
I am not sure if I have a solutions more so than a suggestion. I have done many notebook repairs and one thing that I make sure my techs do is NOT to shock the motherboard (Static, ESD) A simple shock can destroy the video, sound, wireless, and even the hard drive controller. I would check with the company that replaced your LCD and ask if they had trouble with your notebook after the install. Minus the LCD, my first guess would have been to upgrade your memory (maybe), defrag your hard drive and test parts on a good pc. Worst case: replace the motherboard or replace the notebook.
Good Luck
C2Solutions, Inc.
Getting sound crackling issues and slowdown when
just try to repair your Operating system(xp,winvista) and also check if you're have enough memory to run the games,because each and every game have requirement check for these compatibility if your computer is capable to run such games.
How do i download MSI N082 graphics driver
To get the MSI N082 graphics driver:
1. Find your graphics card model. Note down the model number.
2. Go to MSI's website.
3. Look for the support or downloads tab and click on it.
4. Use the search or menu options to find drivers for your specific graphics card model.
5. Download the driver package.
6. Run the installer file once the download is complete.
