20 Most Recent Toymax Skyworth SLTV-2663A 26 in. LCD TV Questions & Answers
I need remote code for skyworth sltv2663a tv to
Skyworth directv remote code is 11256
10/6/2020 10:47:13 PM • Toymax Skyworth... • Answered on Oct 06, 2020
Intermetent power
Hello,The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.All these can be checked on the power supply board.But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.I hope this helps.Regards.
1/5/2012 8:54:40 AM • Toymax Skyworth... • Answered on Jan 05, 2012
Picture has become too big for screen
Used ur tv original remote,look for a button like View Mode,Picture Size,Aspect Ratio,Zoom.Pushes one of these buttons to changes the picture sizes to fit ur tv screen.
6/5/2011 9:30:24 PM • Toymax Skyworth... • Answered on Jun 05, 2011
0answers
How do I fix viore 32'' flat panel that has sound but no picture
Replace the inverter board. www.tvcircuitboards most likely has the inverter board or can get one for you if they dont have one already.
10/31/2012 1:35:35 PM • Toymax Televison... • Answered on Oct 31, 2012
Where might I be able to get a remote for a Avria 32 tv
'32' is a size, not a model number. The search query to find new remote is make model remote replacement.But 'Aria' as a make isn't showing up.https://www.google.com/search?q=avria+32+tv+remote+replacementNormally, you end up at either of these two online retailers.Replacement Remoteshttps://www.replacementremotes.com Sep. 26, 2021 - ReplacementRemotes.com offers Remote Controls, Operating Manuals, Universal Remotes and Accessories for all brands of TV, DVD, HDTV and ...Xfinity XR2 Cable Box Remote... · ‎Contact Us · ‎Hampton-Bay · ‎Harbor-BreezeRemote Replacement - Remotes.com Has What You Needhttp://www.remotes.com/+1 800-736-6837Huge Selections Of Current & Past Models. Shop Remote Replacement To Fit Your Needs! 1-Year Money Back Guarantee. Shop Now & Find Your Remote Replacement Today!‎Call Or Order Online · ‎About 1-800-REMOTES · ‎Commonly Asked Questions..
10/22/2021 3:32:23 AM • Televison &... • Answered 3 hours ago
How to set temperature on msr-nm49
Looks like this might be a stove rather than a television. Please alway put full 'make model (what is it)' in ALL questions. https://www.google.com/search?q=set+temperature+on+msr-nm49 Or maybe one of these? https://www.google.com/search?q=msr-nm49 ..
10/22/2021 3:11:53 AM • Televison &... • Answered 4 hours ago
2answers
Incompatible Disc in Sharp BD-HP21X Blu-Ray Disc Player
I had the exact same problem as you did... I bought the Sharp Aquos 42D85X which came with Sharp BD-HP21X Blu-ray Disc player. could not get brand new blu-ray movies to play and i found it froze everytime after 10 secs. I phoned sharp who basically were no help watsoever! I then went and returned my blu-ray movies back to the store thinking it was a problem with the discs.. The people there were extremely nice and since they had a display model of the BD-HP21X instore they offered to test the movie on it to veroify whether it was the blu-ray player was the problem or not. Turns out its a fault with all of the BD-HP21X models. So we then ended up returning it back to the store we bought it and exchanged it with the older model (BD-HP20X). I now have no problems playing blu-ray movies. Although another suggestion is to perhaps download the lastest firmware update & see if that resolves your issues.
10/22/2021 2:01:51 AM • Televison &... • Answered 5 hours ago
How do I turn off writing when sound bar is on
Can't say I've ever heard of this issue
10/21/2021 9:10:08 PM • Televison &... • Answered 10 hours ago
Please be so kind to email 47 Smart 3D Sinotec 3D Smart TV STL-47P593M manual
Try replacing your main board
10/21/2021 9:09:35 PM • Televison &... • Answered 10 hours ago
UE65MU6179U new mainboard, no picture only backlight and sound
Start by unhooking the cable from the main to power board, see if you get backlights. That will tell if the backlight section is working
10/21/2021 9:08:22 PM • Televison &... • Answered 10 hours ago
Pn51f8500afxza cuts off and on and has red flashing light on front
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. https://elektrotricks.blogspot.com/ http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
10/21/2021 11:55:04 AM • Televison &... • Answered 19 hours ago
In picture mode it doesn't allow me to toggle down for contrast brightness etc
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. http://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/
10/21/2021 11:54:00 AM • Televison &... • Answered 19 hours ago
How do I install web browser on my Sinotec STL- 65u2m led smart tv
Unfortunately you have purchased a television with the Linux operating system. This television is only available in South Africa. https://www.comx-computers.co.za/STL-65U2M-specifications-221164.htm Read this for some ideas to get around it. https://mybroadband.co.za/forum/threads/sinotec-49-smart-tv-playstore-setup.813778/ ..
10/20/2021 3:31:37 PM • Televison &... • Answered Yesterday
Toymax Skyworth SLTV-2663A 26 in. LCD TV Logo
7 questions posted
Top Toymax Televison & Video Experts
Ekse
Tom Chichester
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toymax Televison & Video
Most Popular Question
need remote code skyworth sltv2663a tv
  • Televison & Video
