20 Most Recent Toymax Magnavox 37MF331D 37 in. LCD TV Questions & Answers
Why toymax magnavox 37mf331d 37 in tv worked good i turned it off came back to turn it on and it wont come on the green light that is usually there its not on ?
Fault with the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
11/27/2014 2:48:17 AM • Toymax Magnavox... • Answered on Nov 27, 2014
My magnavox tv worked good turn it off later tryed to turn it on and it wont i notice the green light on the power button wasn't on
Fault with the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
11/27/2014 2:38:18 AM • Toymax Magnavox... • Answered on Nov 27, 2014
2answers
HOW DO I RESET MY TV. IS THERE A RESET BOTTON ON THE TV; 32MD3578
manual. walk thrue the the maual and with you temote, and then fabricreset, are you a mongole or so , reading is hard
11/2/2014 4:44:27 AM • Toymax Magnavox... • Answered on Nov 02, 2014
My magnavox is power cycling with picture and sound but there is an audible pop then it restarts
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
9/3/2014 3:29:03 AM • Toymax Magnavox... • Answered on Sep 03, 2014
Tv went out
check the bulb inside LCD TV...
12/11/2013 7:20:13 PM • Toymax Magnavox... • Answered on Dec 11, 2013
No video
aside from checking connections to see they are right, if using a box remove it and the set from power for a while and then power back to see if it will help or not.
12/13/2012 6:57:19 PM • Toymax Magnavox... • Answered on Dec 13, 2012
Magnavox tv won't turn on or off
Hello,The typical cause of power up problems in a failure of the power supply filter capacitors. The board can be repaired by replacing the bad components. Below is a picture of the power supply board with the bad capacitors circled and below that is a link to a it that is available with the correct parts to rebuild that board.10_1_2012_3_58_30_pm.jpghttp://www.ccl-la.com/catalog/product_info.php?products_id=216I hope this helps you out,BuddyMc
10/1/2012 3:59:44 PM • Toymax Magnavox... • Answered on Oct 01, 2012
2answers
What is the part number for the Magnavox LCD TV 37MF331D, power supply
For magnavox/Philips model #37mf331d/37 part# is 313815864961.
9/24/2012 2:59:53 AM • Toymax Magnavox... • Answered on Sep 24, 2012
WHERE CAN I GET THE CAPACITORS ?????
send a email to [email protected] and include your model number and indicate you need the caps for the power supply. They will have them available.
8/5/2012 9:40:20 AM • Toymax Magnavox... • Answered on Aug 05, 2012
When i turn it on the power light just flashes.
Bad capacitors...location 2074 which is 25volt 2200Mf and cap location 2081 which is 35 volts 1200Mf.
8/4/2012 5:06:06 PM • Toymax Magnavox... • Answered on Aug 04, 2012
2answers
Can i use a 1000uf
Absolutely NO! Although it may be close, you will find a poor startup just as if the set was still bad. The capacitor you need is of course a 25 volt 1200MF. In this case a 35 volt 1200MF will work. I would suggest in this case a next up voltage with the correct MF. In this case the best sub is the 35 volt 1200MF. Check out Matelectronics.com. or MCM Electronics.com or Mouser Electronics .com. If you have a local Electronic supply store they may have what you need. I do not believe you will find it at Radio Shack. Thanks for asking and show a few hands of support!
7/18/2012 4:01:57 AM • Toymax Magnavox... • Answered on Jul 18, 2012
2answers
Need to get a schematic of the power board in a
Replace cap location 2074 which is 25 volt 2200Mf and cap location 2081 which is 35 volt 1200Mf. You can visually see these when you remove the back...Good Luck! PS...be sure they are rated at 105 degrees!!!!
4/12/2012 9:39:32 PM • Toymax Magnavox... • Answered on Apr 12, 2012
Looking for fuses
You must remove the tv from its case, there are fuses and fuse links all over the place on the many circuit boards inside the tv.
1/17/2012 10:50:37 PM • Toymax Magnavox... • Answered on Jan 17, 2012
We have a maxnavox 37 in flat screen HDTV. When
You have a bad capacitor. It will be a 25volt,2200MF, 105 degrees...and it will be bulged! Results will be a AMAZING! Thanks for asking!
12/29/2011 3:16:21 AM • Toymax Magnavox... • Answered on Dec 29, 2011
2answers
I had the same problem with a Magnavox LCD TV. It would not turn on and the light on the external PSU flashed. I found a replacement 12V 5A power supply on EBAY. It brought the set back to life.
11/20/2011 5:30:37 PM • Toymax Magnavox... • Answered on Nov 20, 2011
2answers
I lost the picture on my 37
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
11/20/2011 5:25:52 PM • Toymax Magnavox... • Answered on Nov 20, 2011
Toymax Magnavox 37MF331D 37 in. LCD TV Logo
72 questions posted
Top Toymax Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Larry
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toymax Televison & Video
Most Popular Question
magnavox lcd tv 2006 power light blinks
  • Televison & Video
