20 Most Recent
Samsung SyncMaster 2233BW 22" LCD Monitor Questions & Answers
put another monitor on your computer first so you can see to get on the internet . ..then go to the samsung site and download the drivers for your samsung model and install them into your computer. ...after you install the new drivers then put your samsung back on and your computer should read your monitor then and work
Samsung...
Answered
on Jan 08, 2019
I see this monitor was produced in 2008. I guess you purchased it used. As used monitors cost any where from $10 and up I'd just replace it. It just isn't worth saving.
Samsung...
Answered
on Dec 03, 2017
Turn off the monitor first.
Hold down Function button and click F8 key to tell the laptop to send signal to the monitor.
Samsung...
Answered
on Nov 01, 2017
I had a similar problem with my LCD computer screen. I took it apart and noticed a capacitor that was raised up on the flat end and appeared to be leaking a substance. Replaced it with a similar capacitor and works fine, for three years now.
Samsung...
Answered
on Jul 05, 2017
Check signal cables means there's no signal on input. If your PC still shows up on a different monitor then it's a time to replace a mainboard in your monitor.
Samsung...
Answered
on Jun 03, 2017
Samsung SyncMaster 2233BW does not support TV / Cable input (RF Connector).
If you wish to connect Cable to the LCD, you have to buy a TV Box and connect Cable with your LCD through TV Box. (Cable TV to TV BOX and from TV BOX to LCD)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Samsung...
Answered
on Dec 03, 2016
Check your cables and output signal.
Samsung...
Answered
on Jul 29, 2014
Uhm, monitors don`t have build in sound......
Samsung...
Answered
on Jul 22, 2014
try this right click on your desktop , click on Appearance tab . then click on effects , see if Show shadows under menus is checked if so uncheck it . click ok then click Apply .
Samsung...
Answered
on Apr 29, 2014
Solution for Samsung SyncMaster 2232BWplus:
The problem is bad capacitors: 5 pcs. 820microFarad – 25v and 1 pc. 330microFarad -25v. Replace these capacitors. Then re-solder the two transformers of inverter side. Also re-solder the power transformer and the inductor coil.
To open the casing:
At the bottom of the stand just twist the knob to unlock. Then, use a small flat screw driver beginning from the bottom (left or right) then using a hard credit card (or alike) then slide/glide it in between the cover plastics.
Roan
Triangle Tech Whiz
Samsung...
Answered
on Feb 08, 2014
try to change the plug adapter if isnt workink you get a problem inside at your monitor and there need it an expert
Samsung...
Answered
on Dec 15, 2013
Im glad to know that you have enough knowledge and are able to work inside such electronics. I do have some study/ repair experience of LCD Displays/ Laptop displays. I will describe my point of view in general terms.
There
are two parts responsible for lighting the display. First is the CCFL
(Cold Cathode Florecent Lamp), which is the back light and the second
is the Inverter board, which provides high voltage to the CCFL. Either
of the parts can be faulty or in some rare cases both. But in this case I think it is most likely
the Inverter circuit. (Its life is limited and depending upon how long
it has been in use, you can have a better idea - if its the CCFL or
Inverter)
So, my advice is that you check the Inverter Circiut.
Make sure you take proper precautions while working with it as Inverter generates very high voltage.
Hope this answers your question!
CreativeTECH
Samsung...
Answered
on Dec 01, 2013
Are you using an adapter? The internals might be faulty, so try using a different adapter. Also try using another cable to connect the monitor and desktop. Another thing you could try is checking if your graphics card (if you have one) is properly seated. Finally, check for bent pins on your cable, monitor, and desktop connectors.
Samsung...
Answered
on Nov 30, 2013
Hi there, if you are experiencing something like a white cloud spreading across whole LCD panel, then unfortunately it has to go for a panel replacement .The panels are still expensive so I personally suggest to try buying a new unit cause of the warranty. Cheers.
Samsung...
Answered
on Nov 14, 2013
