20 Most Recent
SPL Audio Phantom DK2-1000 Car Amp Questions & Answers
When i turn the amp on the light turn red and it
when you hooked the amp up did you make sure your speakers were all in-phase positive to postive / etc.. a common issue with hi-power equiptment is grounding whatever input power supply gauge wire was used the ground has to be equalized, also if youre drawing too much on the amp (too much speaker/not enough amp ) this problem will continue till the amp cooks, check all phase, and if youre mono-bridging make sure this amp can be mono-bridgeable that would also send an amp into protection mode because its recognized as a short to positive-good luck
1/17/2010 4:48:50 PM •
SPL Audio...
Answered
on Jan 17, 2010
No sound
unplug spkr from amp and leave rca and turn if this dont happen again check you spk
if it does happen again unplug rca and turn on and if this happen your amp may be bad
6/26/2009 3:49:26 AM •
SPL Audio...
Answered
on Jun 26, 2009
Need help
Hello bully_bread,
Your amp will be powering the sub at 4 ohms.
The impedance or "load" that the amp sees is determined by the number of voice coil(s), the number of sub(s), and how they are connected. Whatever that final load, it is the impedance or "ohms" that the amp is supplying power at.
A single 4 ohm sub with a single voice coil cannot present a 2 ohm load. However, a sub with dual 4 ohm voice coils wired in parallel will present a 2 ohm load.
Here's a link to Rockford_Fosgate's "wiring wizard" where you will find all combinations of subwoofer wiring and the resulting loads.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
Hope this helps.
4/13/2009 5:20:50 PM •
SPL Audio...
Answered
on Apr 13, 2009
When i turn on my
check power connection at ur amp,,,,,,,,,,,
The fuse blew on my
Did you put a new fuse in it? If you didn't then put a new fuse that is rated at what the amp calls for. If you have and the light stays on, then odds are there is a broken wire inside and the amp needs repairing or replacing.
Spl 620 wn put out loud enough
Hello ace_sterling,
Not knowing what you have the SPL-620 driving or knowing how you have it wired, it's rather difficult to determine if it's wired "wrong".
I show the SPL DK2-620 as being a 2-channel amp with 150 watts output at 4 ohms, or 180 watts at 2 ohms. Even if the power is somewhat overrated, it should provide more than enough power for a set of standard 2-way or 3-way speakers, or component speakers with a separate crossover.
Powering one or more subs is another thing. You would get sound, but the subs would not be very loud. In bridged mode, the amp is only stable to 4 ohms. So if you are trying to power 2 4-ohm subs, the best connection would be 1 sub connected to each channel. If you are powering only 1 sub, then the bridged connection would be best.
Hope this helps. If it does, please rate as "FixYa".
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
