20 Most Recent Soundstorm CR4000.1 Car Amp Questions & Answers
0answers
Price of sale
$350
12/4/2010 9:36:20 PM • Soundstorm... • Answered on Dec 04, 2010
0answers
Will the SSL CR 4000.1 work at 0.5ohm
i dont recomment that unless it can handle 1ohm stable you should not try that
11/5/2009 8:19:30 PM • Soundstorm... • Answered on Nov 05, 2009
4000.1 soundstorm amp
Hello GregV24CHOPP,
The Soundstorm products are in about the same category as Boss, Visonik, Pyle, and Lanzar to name a few. Somewhere between overrated and definitely overpriced for the quality you get.
Look into the Alpine MRP-M1000. RMS = 1kW into 2ohms (600 into 4ohms), YES 4 OHMS(!), real power. No, it WON'T do one ohm. But most of those claiming to are not CEA2006 compliant anyway and can claim any power at any load and advertise for whatever buyers they can attract for their bottom-of-the-barrel products.
The MRP-M1000 is currently on sale at Crutchfield for only $347. Awesome power, and very good sound quality, too. I'm currently running 2 4ohm MTX Thunders off of "little brother", the MRP-M500, and they really shake the pavement.
You have to spend good money to get good power, there is no way around that.
The only wiring configurations for 2 2ohm DVC subs result in 0.5ohm, 2ohms, and 8ohms impedance. Check the Rockford-Fosgate "wiring wizard" for the different diagrams.
Hope this helps.
5/13/2009 1:32:43 PM • Soundstorm... • Answered on May 13, 2009
I HAVE A SOUNDSTORM SD960TS AND I DONT HAVE THE
My screen won't come out and when I get it out it's not on I did lose the face but every thing else works what do I do
5/23/2012 4:57:39 AM • Soundstorm Car... • Answered on May 23, 2012
0answers
Can a soundstorm F2500D handle a subwoofer
Hello sincere4140,
The Soundstorm is stable only to 2ohms.
Hope this helps.
7/29/2009 3:48:19 AM • Soundstorm Car... • Answered on Jul 29, 2009
Modelo sd745t radio para coche tengo problemas que el panel fron
Es posible que alguno de los switches este defectuoso y se a de haber quedado oprimido y eso causa que se bloquen todos las funciones.Por lo regular,cuando un switch esta defectoso no se siente el click al oprimirlo.
Espero que esta informacion te ayude en algo.
Gracias y suerte
12/5/2008 12:40:48 AM • Soundstorm Car... • Answered on Dec 05, 2008
2answers
Need the wiring diagram for
The main colors are:
Green - L+
White - L -
Brown - R+
Gray - R-
There are 3 sets of these. The ones with thinner wire are for high level input (from a stereo's speaker outputs). The two other thick sets are the speaker outputs to front and rear. They should've been attached to connectors labeled front and rear, if they aren't, you gotta find out through trial and error with the fader. Lastly, black is for ground of course, then the thin red wire is for 12V+ power (on with ignition), and the thicker red wire is power output to a deck, if you want it to turn on along with the amp/eq.
12/2/2021 5:04:03 AM • Car Audio &... • Answered 3 days ago
3answers
Need Radio wiring diagram 2004 chevy silverado 2500hd (oem plug)
Left Front Speaker(+) TAN ; Size: tab_tech.gif Left Front Speaker(-) GRAY ; Size: Right Front Speaker(+) L GREEN ; Size: Right Front Speaker(-) D GREEN ; Size: Left Rear Speaker(+) BROWN ; Size: Left Rear Speaker(-) YELLOW ; Size: Right Rear Speaker(+) BLUE ; Size: Right Rear Speaker(-) LT BLUE
Yellow -ignition
Orange-Constant +12 volts
Black - ground
If you need more info, please ask.
A rating is appreciated.
11/24/2021 11:08:04 PM • Car Audio &... • Answered on Nov 24, 2021
Ford focus 2011 aux button not working
This isn't an answer but my car is doing something similar. Every time I hit the aid button it goes to fm radio. I've tried doing what some these recommend but nothing is working.
11/22/2021 5:48:02 PM • Car Audio &... • Answered on Nov 22, 2021
Soundstorm CR4000.1 Car Amp Logo
6 questions posted
Top Soundstorm Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Soundstorm Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Soundstorm Car Audio & Video
Most Popular Question
4000 1 soundstorm amp
  • Car Audio & Video
