20 Most Recent Coby TF-TV3217 32 in. LCD TV Questions & Answers
2answers
My 32 inch coby tv wont turn on, how can i fix?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
7/25/2018 1:43:13 AM • Coby TF-TV3217... • Answered on Jul 25, 2018
Coby 32" LCD TV Wire locations
What is the model?...generally you can get a service manual on Coby sets if you do some searching
12/19/2017 3:45:16 PM • Coby TF-TV3217... • Answered on Dec 19, 2017
The Coby flat screen TV
First off, unless you are an electrician or a television repairman that's familiar with very high voltage, It's not recommended that you do anything. It's best to call a repairman to repair. Even with the t.v. unplugged, It still holds a deadly voltage in it.
6/2/2017 7:43:27 PM • Coby TF-TV3217... • Answered on Jun 02, 2017
Coby LCD -TF 3217
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
3/27/2017 4:03:57 PM • Coby TF-TV3217... • Answered on Mar 27, 2017
Why wont my coby stay on?
3/5/2017 4:09:59 PM • Coby TF-TV3217... • Answered on Mar 05, 2017
Devant ER 31951D remote
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician. http://electro-medical.blogspot.com/
1/6/2017 11:22:20 AM • Coby TF-TV3217... • Answered on Jan 06, 2017
I NEED THE CODES NUMBERS TO PROGRAM THIS TV WITH UNIVERSAL CONTROL
GE Universal Remote Codes ' Jasco
https://jascoproducts.com/support/ge-universal-remote-codes
Make a note of which version you have and replace the batteries and cover. A version 2 through version 4 remote will have a "V2" to "V4" after the model number. ... Programyour GE Universal Remote using the correct code list and instructions. ... Sometimes a code will allow limited function control (e.g. volume and channel ...
Universal Remote Control Codes
www.remotecodelist.com/
Codes and links for a number of universal remote controls, including Sony, RCA, ... If you have a remote for which you know the codes (or a web page that lists them) head to ... How to Program a GE Universal Remote Control .... look for your model of TV or VCR and find the online instructions that include the remote codes.
RCA Universal Remote Control- Target Programming ...
7/12/2016 1:21:02 AM • Coby TF-TV3217... • Answered on Jul 12, 2016
My Coby flat screen will cut off after 1minute on ?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
6/16/2016 2:26:08 PM • Coby TF-TV3217... • Answered on Jun 16, 2016
I NEED THE CODES NUMBERS TO PROGRAM THIS TV WITH UNIVERSAL REMOTE CONTROL. TANKS
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://electro-medical.blogspot.com/
1/5/2016 7:52:39 PM • Coby TF-TV3217... • Answered on Jan 05, 2016
I accidently broke it. half is broken. how do i fix it?
you will need to take it to a repair technican
11/22/2015 7:46:05 AM • Coby TF-TV3217... • Answered on Nov 22, 2015
Picture keeps rolling
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
7/27/2015 3:27:05 AM • Coby TF-TV3217... • Answered on Jul 27, 2015
Verticle lines on screen
unfortunately the coby company has gone out of business probably because they have produced an inferior product that has had many, many problems, many people are posting problems with these sets. it is better you just purchase a different brand of tv and leave this heartache causing product behind.
1/24/2015 5:31:05 AM • Coby TF-TV3217... • Answered on Jan 24, 2015
2answers
TV comes on but flashes on and off like a strobe light why?
It must have any defect. My guess is a bad soldering in the power supply. When it gets warm ir will lose he connection. But there could be lots of other causes.
1/18/2015 8:09:29 PM • Coby TF-TV3217... • Answered on Jan 18, 2015
Coby TFTV3227 32 in. LCD TV update firmware
May be the cord not the port and an update on firmware doesnt fix a hardware issue.
10/19/2014 5:27:31 PM • Coby TF-TV3217... • Answered on Oct 19, 2014
The audio on my tv is going on &off, how can I fix it.
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
10/16/2014 12:46:49 PM • Coby TF-TV3217... • Answered on Oct 16, 2014
When powered on my 3217 has no sound or picture. just snow?
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
9/3/2014 4:05:18 PM • Coby TF-TV3217... • Answered on Sep 03, 2014
Need a direct tv remote control code
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/ Code list to direct TV remote control is given with one among the site listed here. I do recall it that I've seen it before.
8/7/2014 4:28:42 PM • Coby TF-TV3217... • Answered on Aug 07, 2014
Coby TF-TV3217 32 in. LCD TV Logo
109 questions posted
Top Coby Televison & Video Experts
Marvin
Marvin
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Coby Televison & Video
Most Popular Question
tv comes but flashes off like strobe
  • Televison & Video
