20 Most Recent Sharp LC-C4654U 46 in. LCD TV Questions & Answers
None of my component inputs
Did you switch the Xbox HD switch to the off position?
1/24/2011 4:33:04 AM • Sharp LC-C4654U... • Answered on Jan 24, 2011
What are the full Hz range capabilities on the
Its frequency depends on which system is doing work pall 50 hz and 60hz ntsc
8/22/2009 7:23:49 PM • Sharp LC-C4654U... • Answered on Aug 22, 2009
How do get full screen on LC-15S2u
Menu on remote and make sure you have it on wide screen or 16 to 9
1/17/2019 10:35:18 PM • Sharp LC... • Answered on Jan 17, 2019
Why isnt roku 3 working through my LC-32DV24U roku 1 worked fine
Hello If your Roku 3 player is not connecting to WiFi, it is possible that the WiFi signal from the router is out of range. In order to strengthen the signal, move the router and Roku 3 so that there are fewer objects and walls between them. For any help or support just visit us: www Roku Com Link
5/26/2018 8:22:34 AM • Sharp LC... • Answered on May 26, 2018
When I connect my wd box to my tv it blacks out every 10 secs very annoying when watching a movie. This doesn't happen when we watch a dvd. When we watch regular cable we see a blue box appears on t
When you say WD box, do you mean a Western Digital Hard Disk Drive? If so, get a Solid State Drive (SSD), and connect it via USB3. The HDD or the USB connection is not fast enough to keep up with the required speed of the video. If you mean something else, please add details.
12/5/2017 9:28:46 PM • Sharp LC... • Answered on Dec 05, 2017
I have a Sharp LCD TV Model # LC 32SB220U. When you turn the power on, within a minute or two, it clicks off. I have tried everything in the instructions to troubleshoot the problem. I also reset to f
Check the high voltage circuit on the board that has the 120 volts input. The high voltage should be close to 400 volts - nothing less than 390 volts. The capacitor is failing to hold the voltage and needs to be replaced.
10/29/2017 1:23:31 AM • Sharp LC... • Answered on Oct 29, 2017
I have an LC-32D33X sharp tv... it just turned off on me :( and now the OPC and the power lights on the tv are flashing SOS style :(
un plug tv and try to force on by pressing vol_ and input button from tv then plug back in see if tv comes on .
12/16/2016 9:30:47 AM • Sharp LC... • Answered on Dec 16, 2016
How do I find out the year my Sharp Aquos TV was manufactured?
Look for it at its bottom side [stand]
9/26/2016 6:46:48 AM • Sharp LC... • Answered on Sep 26, 2016
Instruction manual for Sharp Roku tv LC-32LB481C
Hi, Here you can get solution of your question/problem. https://support.roku.com/hc/en-ca/articles/209403268-Roku-TV-Introduction
9/17/2016 4:39:52 PM • Sharp LC... • Answered on Sep 17, 2016
Sharp LC-C4654U 46 in. LCD TV Logo
7 questions posted
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
LC Sharp
  • LC Sharp
Most Popular Question
none component inputs
  • Televison & Video
