20 Most Recent Hitachi P42A202 42 in. Plasma TV Questions & Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Hitachi P42A202... | Answered on Nov 13, 2014
shrc 2000, Yes, you too, will need to watch some video clips at YOUTUBE about replacing some capacitors on the internal SMPS dc supply board. Maybe you have swollen, bulging capacitors. If so, please state the brand name of the capacitors you find in that condition. How old is your unit?? Did it work perfectly last month? If not into removing rear cover of unit, then call a service technician who can troubleshoot "switch-mode-power-supplys. There is lots of info on "bad capacitors" on the web already. Just search "CapXon capacitors" and ee how many "hits" you get. 12fixlouie
Hitachi P42A202... | Answered on Aug 20, 2010
The TV most likely will have component and a DVI connector on it if it doesn't have a HDMI connector. If the Blu-ray player has component connectors on it use them as they will give you up to a 1080i picture which is all this model of Hitachi supports anyway. If the player doesn't have component connections then you can get a HDMI to DVI converter cable so you can connect it to your TV. You will need a cable that looks like this...
http://www.kmart.com/shc/s/p_10151_10104_25000PCM-2296-06P?vName=Computers%20&%20Electronics=&cName=HomeTheater&Audio=&sName=Accessories&psid=FROOGLE&aff=Y&sid=KAx20061023x272xTier3
Hitachi P42A202... | Answered on Nov 11, 2009
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
View the site by desktop or web view on mobile devices to see the "search box". Type in the brand name of your set in search box; to get gathered the related posts.
Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Hitachi... | Answered on May 27, 2020
First make sure that the current Source or Input is set to TV. This is usually the only reason for the error message you see. To select the source, look for a Source or Input button on the original remote. If you have an universal remote with a button with the Source/Input label, you may need to try alternative codes to make the button work. (Power and channel controls will often match across multiple codes for the TV manufacturer.) Alternatively, check if there is a Source/Input button on the TV or a section of the menu system with the function. Once you set this source, try again.
Note: there was a period when manufacturers sold some TVs without tuners. They were labeled HD-ready sets. These can't do a channel scan and do not have an RF antenna jack on the set.
I hope this helps. Please add a comment with the model number of your Hitachi TV for more information on setting the source on your set.
Hitachi... | Answered on May 22, 2020
Depends on the model number.
Under Audio or Audio Settings on the on-screen menu, TV Speakers is set to On. All of the cables physically connected to the TV and the input devices are secure. Switch to a different input device and verify there is sound from the TV speakers (for example, a DVD player or a gaming console).
https://www.ifixit.com/Answers/View/310570/The+sound+on+my+TV+stopped+working.
Hitachi... | Answered on May 17, 2020
It is reporting reduced air flow due to a clogged filter. Swing the case upwards, remove the filter and wash it is soapy water. Rinse, dry and replace it.
See yonder videos
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk00iKHgEuCo9ZiAKv6-cznuCodHQQA%3A1588957722275&ei=GpK1Xo6xEI6PtAbs3IHgCg&q=hitachi+air+conditioner+filter+cleaning
Hitachi... | Answered on May 08, 2020
look on the back of the television and the DVD player, there should be a SCART socket and/or red, white and yellow AV sockets, either use a SCART lead and connect it to the SCART on the DVD player and the TV.Or use an AV lead with 3 auxiliary shape connectors and match the colour of each connector with the female sockets on both the TV and the DVD player instead of using the other component connections.
Hitachi... | Answered on May 07, 2020
What is the problem you faces with this TV? Provide more details, please. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy.
Hitachi... | Answered on Mar 11, 2020
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Hitachi... | Answered on Feb 28, 2020
Without a remote control, you can't unlock it. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops; and by Online shopping.
Hitachi... | Answered on Feb 12, 2020
Soooo...execute it
Hitachi... | Answered on Jan 26, 2020
Hitachi P42A202 42 in. Plasma TV Logo
Popular Tags
11 questions posted
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
hitachi plasma 50 tv model p42a202 s
  • Televison & Video
