20 Most Recent RCA L32WD22 32 in. LCD HDTV Questions & Answers
2answers
2answers
I have no remote for an rca l32wd22 hdtv lcd tv and cannot find the inputs to change to HDMI?
Unfortunately, the L32WD22 doesn't have an Input button on the front panel of the TV. You need a remote control that matches the Input code for the remote. Here's one link to a remote that should work: http://remotes.com/store/rca/l32wd22.html . Other universal remotes may work if you find the correct code if the remote has an Input or Source button. I hope this helps. Cindy Wells
5/7/2017 1:44:18 AM • RCA L32WD22 32... • Answered on May 07, 2017
After power outage TV will not turn on. No lights are on. I had it plugged into a surge protector when power failed?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
5/6/2016 7:51:47 AM • RCA L32WD22 32... • Answered on May 06, 2016
2answers
Light comes on (flashing amber
My friend Maurice gave me a L32HD31YX16 with the same problem, no picture no sound, after four hours of research and trouble shooting, no schematics.
I had no +12 and no +24 volts on the power supply board. I did have the +5V.
The repair is an 85 cent fuse under the blue transformer, There is a 200mA fuse, green with a "C" on it, at location RB8 (1206 package).
I went to the shack bought a 250mA glass fuse and holder for 5 dollars just to get it done. So far the unit has run for an hour.
IRB
1/2/2016 9:44:59 PM • RCA L32WD22 32... • Answered on Jan 02, 2016
Vertical colored lines on entire screen, sound ok
Hi. Probably the t con board of your TV is faulty. T con board is the one which drive the lcd pixels. You have to replace the T con board to get it work properly. Here i have added the picture of the T con board of your tv for reference.also added the video to know how to replace the T con broad. RCA L32WD22 T-CON BOARD UT-5531T03088-76J 25856984-hxcf1nwnv1lguy1e3r5wug4i-3-0.jpg Samsung TV Repair How to Replace Con Board in LJ94 02 705E Model How to... www.electro-medical.blogspot.com
9/9/2015 6:14:15 PM • RCA L32WD22 32... • Answered on Sep 09, 2015
What needs to be done to fix a constant buzzing sound?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
6/30/2015 5:30:34 AM • RCA L32WD22 32... • Answered on Jun 30, 2015
The power was coming off and on .now i got it on and the pic is black and white
faulty connections in tv boards ie dry joint
4/21/2015 1:15:58 AM • RCA L32WD22 32... • Answered on Apr 21, 2015
What is the code for an Rca Lcd tv using a Ge universal remote?
0267,0284,0292. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
9/4/2014 9:16:41 AM • RCA L32WD22 32... • Answered on Sep 04, 2014
Does this tv have an internal converter box
Here is a helpful link: http://www.cnet.com/products/rca-l32wd22/specs/ According to this link, no, it will not tune the over the air "ATSC" signals, it will tune what some cable company's have switched to refereed to as Clear QAM. For a "cable company converter" it would need a cable card slot.
8/21/2014 7:37:52 PM • RCA L32WD22 32... • Answered on Aug 21, 2014
How do you hook up a DVD player to a RCA LCD TV?
If they both have HDMI inputs and outputs use those. If not use the RCA audio and video jacks. Make sure you change the settings on the TV so it knows where to look for the input signals.
8/13/2014 4:18:09 AM • RCA L32WD22 32... • Answered on Aug 13, 2014
LED TV SAMSUNG series 6 red light flasiing 2 times tv won't come on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
5/19/2014 8:29:28 AM • RCA L32WD22 32... • Answered on May 19, 2014
0answers
Color problem
if ur saying abt the graphic setting thn u can graphic properties, if it is not thn u can change it frm the monitor control option. to make normal RGB
1/4/2014 12:01:32 PM • RCA L32WD22 32... • Answered on Jan 04, 2014
RCA L32WD22 32 in. LCD HDTV Logo
152 questions posted
Top RCA Televison & Video Experts
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
after power outage tv will not turn no
  • Televison & Video
