20 Most Recent RCA L42FHD37 42 in. LCD HDTV Questions & Answers
Must be a dirt cheap part if they are willing to absorb that cost and just charge for labor/ unit is out of warranty. May be a power supply issue and that is something worth checking if the supply is very reasonable in cost. TV Parts Universal TV Stands DLP Chips ShopJimmy Sears Online In Store Shopping Appliances Clothing More
RCA L42FHD37 42... • Answered on Sep 20, 2017
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
RCA L42FHD37 42... • Answered on Jan 20, 2016
Recommend contacting the seller and tell them you are bringing it back and why.
RCA L42FHD37 42... • Answered on Mar 05, 2015
likely you have set the resolution higher than the monitor can handle, try lower resolution like 1024 X 768 Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
RCA L42FHD37 42... • Answered on Nov 25, 2014
T'Con board fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/
RCA L42FHD37 42... • Answered on Jul 19, 2014
Hi here is a link to the manual for your tv. please rate me i need 3 more to get my badge thank you
RCA L42FHD37 42... • Answered on Apr 01, 2014
Motorola remote control have no setup codes to Sony Bravia HTS. If you wish to get some details, check the sites linked here. Set-up code list, and Set-up procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name of your TV / Device, in the search box at the top right of the display window.
RCA L42FHD37 42... • Answered on Nov 11, 2013
If you have this comcast Universal Remote - Red OK/Select Button here are the codes Sony 11100, 10000, 11317
if this doesn't work use the search mode
Searching For You our Code
If your home entertainment device does not respond to the remote control after trying all of the codes listed for your brand, or if your brand is not listed at all, try searching for your code.
For example, after trying all of the codes for your TV, you still cannot get the remote control to operate your TV, then:
1. Turn on your TV.
2. On the remote control, press TV once. Then press and hold Setup until the TVTV key blinks twice, then release Setup.
3. Enter 9 - 9 - 1. The TV key will blink twice.
4. Press and release the digit 1. The TV key will blink twice.
Note: Substitute 1 with 0 if searching for a Cable code, 2 if searching for a DVD, VCR or PVR and 3 if searching for an Audio device
5. Press Power and aim the remote control at the TV and press CH + one or more times until the TV turns off.
NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first.
6. Press Setup once to lock in the code.The TVTV key will blink twice.
7. To search for the codes of another device, repeat steps 1 to 5, but substitute the AUX key for the device you are searching for.
Checkcking the Codes
If you have set up the remote control using the Searching For Your Code
procedure, you may need to find out which five-digit code is operating your equipment. Perform the following steps after setting up your devices to find out which five-digit code operates your equipment. For example, to find out which code is operating your TV:
1. Turn on your TV.
2. On the remote control, press TV once. Then press and hold Setup until the TV key blinks twice, then release Setup.
3. Enter 9 - 9 - 0. The TV key will blink twice.
4. To view the code for the first digit, press 1 once. Wait 3 seconds and count the number of times the TV key blinks (e.g., 3 blinks =3) and write down the number in the left most TV Code box (at end of this section).
NOTE: If a code digit is "0", the selected mode key will not blink.
5. Repeat step 4 four more times for the remaining digits. Use 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the fifth digit. Finish writing down the code in the TV Code boxes (at end of this section).
It can be a pain but once you get it down its a cake walk.
RCA L42FHD37 42... • Answered on Nov 10, 2013
I see so many here with no sound/nopicture issues:ISSUES: 1. IF sound main fuse/s are good.2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.4. Be safe and if you do not know what you are doing don't open the set.Answers to issues:1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.4. Safety first--no TV set is worth getting injured or even killed over.4_3_2012_1_05_57_pm.jpg4_3_2012_1_06_30_pm.jpg
RCA L42FHD37 42... • Answered on Sep 13, 2013
When using VGA, you will need to run another cable from the audio out of the other device to the red and white RCA connectors on the back of the TV labeled Audio Input (left & right).
RCA L42FHD37 42... • Answered on Sep 11, 2013
Check ad replace the main digital processor board.
RCA L42FHD37 42... • Answered on Oct 16, 2012
the screen might be broken. when that happened to one of mine i found a crack on the edge of the screen in the glass/plastic? type stuff but it only affected the aria right near the crack. found out my roommate chucked his glasses at it. if not idk
RCA L42FHD37 42... • Answered on Sep 30, 2012
RCA L42FHD37 42 in. LCD HDTV Logo
83 questions posted
Top RCA Televison & Video Experts
Paul Bade
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
rca l42fhd37yxii dark green light gray
  • Televison & Video
