20 Most Recent Mitsubishi WD-65C8 65 in. LCD HDTV Questions & Answers
Open up the front lower panel. You will find several screws that hold another panel cover. Remove the second panel and you will find 6 knobs that will help adjust your coloring and fine tuning.
Mitsubishi... | Answered on Nov 05, 2014
You need to replace your power supply board. They can be had at www.shopjimmy.com
Mitsubishi... | Answered on Jan 09, 2014
check your audio settings,
Mitsubishi... | Answered on Dec 24, 2013
I have personally had this problem, you have the cords in the wrong place.
Mitsubishi... | Answered on Nov 03, 2013
Common Repairs
For the following models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD-65732, WD-57831, WD-65831, the most common repair problem stems from television shutting off almost immediately after it has been turned on accompanied by the message, "TV will shut down in a few seconds. Please check if the air flow is blocked." According to the Mitsubishi website, this issue is caused by a loose connection as a result of a faulty thermal sensor. For models: WD-73727, WD-73827, WD-73927, WD-73732, WD-7383, the most encountered repair problem has been in relation to the optical engine. Another common situation consumers have encountered is failure of the TV to turn on along with unceasing flashing of the green power light. The solution for this problem, caused by the DM board, will vary by repairman. Consumers have also encountered issues with moving vertical or horizontal lines appearing on the screen which can either be due to problems with the capacitor, light engine, or formatter board. Make sure all bad caps are changed.
Mitsubishi... | Answered on Jul 07, 2013
If you have a dark picture I would first check lamp and see if correct, and if correct you could have a bad or weak ballast, but I would buy new mits lamp and replace and see if this helps if not check ballast
Mitsubishi... | Answered on Apr 17, 2011
Please refer to the link below for the manual of Mitsubishi WD-65C8
http://www.retrevo.com/support/Mitsubishi-WD-65C8-TVs-manual/id/21395ag201/t/2/
Mitsubishi... | Answered on Nov 08, 2010
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
These steps are actually for a Mitsubishi Projection HDTV, but I think they may work for a Mitsubishi LCD HDTV too.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Mitsubishi... | Answered on Apr 30, 2010
The main setting is usually the brightness, contrast and hue, do it manually until you're satisfy with the results
Mitsubishi... | Answered on Jul 28, 2009
turn down volume see if you hear a noise from back where color wheel is located
Mitsubishi... | Answered on Jun 19, 2020
Is yours fitted with a fuse in the wall plug? Replace that and see if that fixes the issue. Often the checking the simple stuff first saves you a lot of money.
Mitsubishi... | Answered on Jun 12, 2020
Hello There!!!!!!
Well this is gonna take some work... First thing to start with is...
When you replace the bulb/s -does the bulb actually illuminate?
If you shine a very bright light into the surface of the screen can you see a faint image of whats on the set?
Do you get sound?
If the bulb is illuminating, is it blowing soon after?
Did the set return to normal operation after replacing the bulb the first time?
Side Note-Never touch a high power bulb glass enclosure because you can leave oils and moister that lesson the life of the bulb or make it more prone to blowing. I have no facts to support this note beside my own experiences but this is a known "thing".
Questions? Just ask. Mr.Mike
Mitsubishi... | Answered on May 20, 2020
Several problems may cause your Mitsubishi television to shut off by itself. ... Plug the television in, replace the fuse or reset the circuit breaker as needed. If the light is blinking green, a power surge or unusual digital signal was detected by the television. To prevent damage, the television shut itself off.
Mitsubishi... | Answered on May 12, 2020
Xplain issue bettr..giv som details
Mitsubishi... | Answered on Apr 30, 2020
Mitsubishi WD-65C8 65 in. LCD HDTV Logo
24 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
cause shadowing pastel colors when
  • Televison & Video
