20 Most Recent Sony BRAVIA KDL-52S4100 52 in. HDTV LCD Questions & Answers
How o get to sony bravia KDL- 52S4100 tv menu
Press button marked"menu"
12/6/2016 11:13:49 PM • Sony BRAVIA... • Answered on Dec 06, 2016
What are the codes for a sony t.v.
For which remote exactly? Each manufacturer of programmable/learning remotes has their own code base and unique numbers for each code. Asking for a code is like asking for the postcode/zip code of Acacia Avenue but without specifying the city and district.
9/10/2014 12:45:23 PM • Sony BRAVIA... • Answered on Sep 10, 2014
2answers
Left half of my TV screen is completely white
That is only available to Sony authorized servicers. See esupport.sony.com
8/14/2014 10:25:54 AM • Sony BRAVIA... • Answered on Aug 14, 2014
0answers
KDL-52XBR6 T-CON decodering board
Usually it is t-con bad. You can find it here:1-857-237-12 LJ94-02383 Sony KDL52XBR6 T-Con modulelink:http://www.ebay.com/itm/170994317153?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
2/22/2013 2:28:41 PM • Sony BRAVIA... • Answered on Feb 22, 2013
52'' Sony Bravia will not turn on
Its fixable problem like power supply board replacement will solve the problem.
Unplug tv from wall socket for couple of minutes, replug back in and turn it On.
If problem still exist then most likely power supply got fired and will be replaced, local tv repair shop will help you to replace power supply board.
Thanks.
1/25/2013 12:00:43 AM • Sony BRAVIA... • Answered on Jan 25, 2013
Sony bravia kdl-52s4100 no picture or sound
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
11/30/2012 3:50:49 PM • Sony BRAVIA... • Answered on Nov 30, 2012
2answers
Sony kdl-52s 4100 power supply ok but no sound and display
Well, if the power supply is in good working order, you will need to verify that the proper voltages are getting to the main board. If the main board is getting the proper voltages, I would bet you have a defective main board. The video and audio signals are generated on the main board. Expect to pay $100-$150 for a replacement main board.
11/27/2012 6:58:07 AM • Sony BRAVIA... • Answered on Nov 27, 2012
0answers
Sony tv two blink code
OCP ( Over Current Protection ) 02Main power supply regulator board might need replacement. Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 900 posts to different brand TVs now.
10/3/2012 2:56:16 PM • Sony BRAVIA... • Answered on Oct 03, 2012
Picture won't refresh on left 1/4 edge of screen
It may and likely is a defect inside the display panel itself.
6/17/2012 5:39:49 PM • Sony BRAVIA... • Answered on Jun 17, 2012
Sony kdl-52w3000 has a yello vertical line on lh side and reddish line in the middle. The left side is a little lazy slow as well. How do I fix it?
Take it to a shop for a estimate unless you want to start buying circuit boards and replacing them to see if it is a board or the display panel itself.
6/15/2012 6:58:28 PM • Sony BRAVIA... • Answered on Jun 15, 2012
Sony hdtv screen distortions when you first turn it on
There are some components on either the driver board or in the panel itself that have become thermo sensitive. This would entail changing a board or the panel itself. These are not supported or usually possible to service at the component level. The circuit boards are in multi layers, and the components are mostly surface mount. Get an estimate from the factory service before committing to service the set. It may be more feasible to replace the set than to fix it. This usually the case with this type of technology. Jerry G.
6/7/2012 7:08:14 AM • Sony BRAVIA... • Answered on Jun 07, 2012
Red blinking standby on my sony tv
That problem is cause of faulty power supply board..look at the capacitors if bulged then try to replace it..Watch this video to learn more about capacitors:If you have soldering skills its better to buy a new power supply board online...
2/3/2012 10:36:41 PM • Sony BRAVIA... • Answered on Feb 03, 2012
0answers
Sony BRAVIA KDL-52S4100 52 in. HDTV LCD Logo
58 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
sony kdl 52s 4100 power supply ok but no
  • Televison & Video
