20 Most Recent Sharp 32SC260 32 inch TV Questions & Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock and to set the device region free procedure of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Sharp 32SC260 32... | Answered on Oct 20, 2017
Flashing of power light are fault indications. These are called blinking codes. Count the number of blinks occur one time switch on. It will give you an idea about the faulty section circuit inside. If you wish to know more about these blinking codes, check this link.
Sharp 32SC260 32... | Answered on Feb 22, 2013
Verticals through the picture often denote that other televisions in the house or area are effecting your viewing. The only way that can take place is if your signal is too weak to overcome it. It is not your TV but as you've suspected, a lack of quality signal. Call your cable provider for a service tech to sort out a solution. You could take the set over to another friends and prove the TV is OK.
Sharp 32SC260 32... | Answered on Dec 05, 2010
check out if it had a earphone out, if there is, got a earphone plug to it, if theres a sound being heard at the earphone, a loose at earphone jack is the situation....
Sharp 32SC260 32... | Answered on Dec 31, 2009
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
View the site by desktop or webview on mobile devices to see the "search box". Type in the brand name of your set in search box; to get gathered the related posts.
Just note; some models of Sharp televisions uses Philips circuit board.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Sharp Televison... | Answered 3 days ago
I had the same problem. Try this. Contact Sharp and have them email you the firmware update. You will need to download it from the email and transfer it to the player via a flash drive. See if that works. I am about to return my Sharp Blu Ray player to Costco and go back to DVD. There seem to be a lot of problems with the technology. Even when movies start to play, they have freezes and it is sometimes hard to get the menu to show up
Sharp Televison... | Answered on Jun 29, 2020
Possibly stucked volume button on tv
Sharp Televison... | Answered on Jun 22, 2020
If you wish to get some details; check the site linked here. Pull up older posts.
https://elektrotricks.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Type in the brand name of your device in the search box, and hit enter to get gathered related posts. See the website either in Webview with a mobile, or by a desktop computer. Mobile view has no search box in it.
Sharp Televison... | Answered on Jun 03, 2020
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sharp Televison... | Answered on May 29, 2020
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
View the site by desktop or web view on mobile devices to see the "search box". Type in the brand name of your set in search box; to get gathered the related posts.
Sharp Televison... | Answered on May 28, 2020
Sharp 32SC260 32 inch TV Logo
Popular Tags
9 questions posted
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Televison & Video
Most Popular Question
grandson turned
  • Televison & Video
