20 Most Recent Toshiba MW27H63 27" TV/VCR/DVD Questions & Answers
Black tv screen with line across
Vertical output IC has failed. It should be replaced. You haven't given the brand name and model number here. I assume that it is a Toshiba TV. If so, Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as service help to electronic home entertainement equipments.
Pull up older posts. You can gather all details. Sometimes, clicking on the ads by the side and bottom of each post might give you more details.
5/28/2012 2:14:19 PM • Toshiba MW27H63... • Answered on May 28, 2012
Retail price tosiba 35a44
Ask to Toshiba dealer.
5/23/2012 4:07:12 AM • Toshiba MW27H63... • Answered on May 23, 2012
2answers
White lines at top of
Replace all the in the vertical section, it will be by a IC that has five to seven legs mounted to a heat sink.
12/21/2010 12:13:58 AM • Toshiba MW27H63... • Answered on Dec 21, 2010
What code do you need for a Toshiba SE-R0168 remote control please?
This appears to be a multifunction remote for various Toshiba devices. The code will depend on the device you are wishing to operate. https://www.google.com/search?q=toshiba+SE-R0168 Google Toshiba (DVD / Television / Stereo) remote codes
12/3/2022 5:10:52 AM • Toshiba... • Answered on Dec 03, 2022
Toshiba 50L4300U will not turn on, no sound no picture, dead as a doornail.
Question edited for clarity. You have done all you can, it is broken and needs fixing. If you try and fix it yourself, this will happen. https://www.fixya.com/support/r29790007-repairing_own_television ..
12/3/2022 5:06:26 AM • Toshiba... • Answered on Dec 03, 2022
2answers
Anyone know the TV codes to program my Panasonic theater system compatible universal remote?
1003,1010,1049,1053,1096,1123,1152,1231,1289,1292,1295
12/2/2022 3:49:52 AM • Toshiba... • Answered on Dec 02, 2022
2answers
How come my 10-year-old toshiba tv now goes to screensaver in the middle of a program I'm watching
Hi, Please factory reset your toshiba tv or update your tv settings so that the screensaver is disabled. Either of these 2 actions should help you overcome this issue. If you don't see a screensaver option on your remote, please reference the table of contents within your manual. Thank you.
11/5/2022 4:23:48 AM • Toshiba... • Answered on Nov 05, 2022
2answers
Toshiba 49L420U does not turn on
The 5 and 3.3 voltage is standby and that would be good if you get a standby light, you won't see the 16 volt unless the power supply is at full power or out of sleep mode. Look at the legend on the power board connector going to the main for something like PWR_ON, it may be marked different, but will have something about power on, you need to see just over 3 volts there when you push the power button, if 3 volts is there replace the power supply, if you don't see that go to the connector coming from the inferred board on the main board, measure the voltage at the pins, one will be 5 volts and one of the others need to change voltage when you push the power button on the remote, measure these one at a time, if none chance replace that board, if you see a change in voltage on one of the pins replace the main board.
9/14/2022 12:03:24 AM • Toshiba... • Answered on Sep 14, 2022
Toshiba TV Stuck in Standby
Are the lines always vertical or horizontal? Are they black or multiple colors?
9/5/2022 9:12:01 PM • Toshiba... • Answered on Sep 05, 2022
Hisense tv struck by lightning repair kid
Total right off unfortunately. 125,000 volts is very damaging to all the components. Claim on house insurance, some cover it.
9/5/2022 8:40:01 PM • Toshiba... • Answered on Sep 05, 2022
2answers
Trouble with Toshiba flat screen
Over time with heating and cooling of the power board the fuse holder loses tension and won't make proper contact with the fuse, remove the fuse and bend the contacts together and see if it works, if it still gives trouble replace the power supply or solder the fuse to the holder if you have a soldering iron and can do the repairs.
8/19/2022 9:59:07 PM • Toshiba... • Answered on Aug 19, 2022
2answers
Same problem, my Toshiba 26AV502R not powering on. I found the ceramic fuse blown on the power board & replaced it. The new fuse blew the instant I plugged the TV in. Any idea what is causing this?
Replace the power board if you can find one, unless you're an electrical engineer with the proper test gear high speed switching power supplies are to complex to service
8/19/2022 5:10:17 AM • Toshiba... • Answered on Aug 19, 2022
I have a Toshiba W255 VCR hooked up to a Kinivo HDMI switch via an hdmi converter to an older Panasonic plasma TV.
try a converter box that allows multiple devices
8/19/2022 4:53:45 AM • Toshiba... • Answered on Aug 19, 2022
Internet on my old Toshiba RV75
Probably you need a digibox between your internet connection and the old TV.
8/14/2022 6:47:54 PM • Toshiba... • Answered on Aug 14, 2022
I have a Toshiba dvr620 and can't remember which buttons to push to activate the sound.
What TV or monitor is your DVR620 connected to? There is an Audio button on the original DVR620 remote (not a universal remote), it's just above the TOP menu (displays the Title List for the current video). This lets you access a DVD audio menu or change a VHS playback between Hi-Fi or mono audio out. All other volume changes will be controlled by the controls for your TV or sound system. (This will depend on which video/audio out you have connected. Optical and some RCA audio output choices will be connected to an amplifier or home theater speaker system. If you are using HDMI or component/composite cables to a TV, then the TV speakers are probably active.) The manual for the Toshiba DVR620 is available at Crutchfield on the product page: https://www.crutchfield.com/S-Qjp9jnoviHC/p_052DVR620/Toshiba-DVR620.html . Look under the What's in the box header on the right side of the page. The current link to the manual is https://pdf.crutchfieldonline.com/ImageBank/v20101107082900/Manuals/052/052DVR620.PDF . I hope this helps. Cindy Wells (If you have the DVD recorder connected to a monitor that doesn't have speakers, connect one of the audio out options to a sound bar or other audio equipment.)
8/8/2022 10:43:30 PM • Toshiba... • Answered on Aug 08, 2022
Toshiba MW27H63 27" TV/VCR/DVD Logo
4 questions posted
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
white lines top
  • Televison & Video
