20 Most Recent Amana DigiSmart PTH153B35AM Thru-Wall/Window Air Conditioner Questions & Answers
Is there a reset on the cord?
Amana DigiSmart... | Answered on Oct 12, 2016
Check limit or thermo switches
Amana DigiSmart... | Answered on Nov 10, 2013
Turn "off" the "energy saver" feature....
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Amana DigiSmart... | Answered on Jul 19, 2010
If this is a window unit, the tray drain is located at the bottom outside. It may be clogged, but also the unit may not have been installed correctly to direct water flow toward the outside drain.
Amana Heating &... | Answered on Nov 22, 2020
All this means is that the Copeland monitor is sensing amp draw on the compressor but it is not detecting a Y signal calling for the compressor to run. If there is no problem with the contactor and equipment is running fine, check for the jumper wire that carries the Y signal over to the compressor monitor.
Amana Heating &... | Answered on Nov 12, 2020
Goodman Industries has purchased Amana. So go to Goodman website for info. Without model number I cannot look up error code
Amana Heating &... | Answered on Feb 19, 2020
You need to reinstall the software http://rollingskygame.com/run-3
Amana Heating &... | Answered on Dec 02, 2019
What is -the outside?
Heat pump, gas, electric heat combination?
You may need to back track, double check the Honeywell configuration jumper or software settings for your type of heating used.
Amana Heating &... | Answered on Nov 09, 2019
There should be a fan symbol on your remote control. In the "mode" control, there should be the following options.. Heat, cool, Auto and fan. If you select fan, only the fan will run. No heating or cooling.
Amana Heating &... | Answered on Jun 10, 2019
Check voltage in , there could be one side of breaker burned causing only one side to come through. This happens on older main breakers frequently which messes up whole house.
Amana DigiSmart PTH153B35AM Thru-Wall/Window Air Conditioner Logo
9 questions posted
Top Amana Heating & Cooling Experts
Dennis Boxerman
James Bradburn
James Bradburn
john h
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Heating & Cooling
Most Popular Question
no power control panel unit
  • Heating & Cooling
