20 Most Recent Amana PTC153B50AM Split System Air Conditioner Questions & Answers
Have an identical unit. Replaced the heater core which has built in limit switches. Didn't fix. Finally fixed it by replacing the heater relays (small black boxes soldered into the circuit board). Can purchase at Digi-Key online for $4 apiece or buy a new circuit board for about $100.
Amana... | Answered on Dec 14, 2014
The heater relays (little black boxes marked "heater 1" and "heater 2" on the circuit board are known for going out. $100 will buy you a new circuit board, or you can order the relays from Digi-Key for $4 apiece if you are willing to solder them in yourself.
The heater relays on the circuit board are famous for going out in this model.. Can purchase circuit board for about $100 or individual relays for about $4. Have to solder them in.
Sounds like you have a heat pump with either a stuck reversing valve or a loose wire going to the reversing valve solenoid. Open it up and take a look. Keep slapping it and you'll break something!
Amana... | Answered on Dec 06, 2014
the compressor is controled seperately from the fan, this is done with the thermostat, try turning the thermostat on then of or untill you hear the "click" sound from the thermostat. If the compressor is still not turning on this may be more than you can fix if your not familiar with electrical hvac troubleshoting... more than lilkely the thermostat may be bad, or your compressors starting components are failing...if the compressor is comming on when the unit is turned on you could have a freon leak causing no heat. hope this may help some there is just too much to write on the causes this will give you a start though!!
As long as you have the part number, if you have a D&L parts company listed
nearby, they can probably get it for you. They sell over the counter and even
UPS parts. They have a website as well. (This is where I get my PTAC
control boards). Hope this helps.
Amana... | Answered on Mar 06, 2011
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Amana... | Answered on Jan 11, 2011
Hello tkulsicki. Begin by checking to be sure that their is power at the outlet where you are plugging in the appliance. If you do not have a tester, the least expensive way is to go to the hardware store and buy a light bulb socket with pigtail and a 15 watt bulb. Use this to see if the outlet works. That is the first step. After that, assumming that the outlet is live, your circuit board is the next suspect item.
If there is no power at the outlet but the circuit breaker appears to be on, then most likely the circuit breaker itself is bad and needs to be replaced. Joe
Amana... | Answered on Nov 17, 2010
Check filter,and clean , and outside cond. unit most probably needs cleaned. Wash it out with a water hose,not high pressure, and it should work better.
Amana... | Answered on Feb 23, 2010
AMP TEST THE HEAT ELEMENTS , SEEM LIKE A BAD ELEMENTS
Amana... | Answered on Dec 02, 2009
Sounds as though the power cord reset switch might be bad and need to be replaced. If not, then there is a short somewhere in the system. Do an ohms test on the switch to determine if it is bad.
Amana... | Answered on Mar 17, 2009
If this is a window unit, the tray drain is located at the bottom outside. It may be clogged, but also the unit may not have been installed correctly to direct water flow toward the outside drain.
Amana Heating &... | Answered Yesterday
All this means is that the Copeland monitor is sensing amp draw on the compressor but it is not detecting a Y signal calling for the compressor to run. If there is no problem with the contactor and equipment is running fine, check for the jumper wire that carries the Y signal over to the compressor monitor.
Amana Heating &... | Answered on Nov 12, 2020
Goodman Industries has purchased Amana. So go to Goodman website for info. Without model number I cannot look up error code
Amana Heating &... | Answered on Feb 19, 2020
You need to reinstall the software http://rollingskygame.com/run-3
Amana Heating &... | Answered on Dec 02, 2019
What is -the outside?
Heat pump, gas, electric heat combination?
You may need to back track, double check the Honeywell configuration jumper or software settings for your type of heating used.
Amana Heating &... | Answered on Nov 09, 2019
Amana PTC153B50AM Split System Air Conditioner Logo
Popular Tags
18 questions posted
Top Amana Heating & Cooling Experts
Dennis Boxerman
James Bradburn
James Bradburn
john h
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Heating & Cooling
Most Popular Question
amana air heating unit model
  • Heating & Cooling
