20 Most Recent Haier HPRB07XC7 Portable Air Conditioner Questions & Answers
3answers
The alarm light on my Haier HPRB07XC7 Portable Air
I had the same problem. I found the micro-switch for the water level was faulty. This switch had a high fluctuating resistance. I was able to correct the problem by spraying some contact cleaner ( or use TV tuner cleaner, alcohol might even work) into the switch. The resistance then dropped to 0.6 ohms. The only place I saw to get the cleaner inside, was around the depress-pin itself. It obviously got inside. If facing the unit, this micro-switch is located on the left lower inside, you can't miss it. You can see where the water float level lever mechanism depresses this switch. Getting the cover off was aggravating, but wasn't too bad. Remove the front cover's 2 bottom screws and lift up and off the front. Remove the left side 3 screws and the rear panel 4 screws and this gave me enough play to prop up the left side panel to get to the switch. The switch removes super easy. For troubleshooting purposes, you could jumper the 2 wires together, that are connected to the switch, as the switch is used in a 'normally closed' application. Essentially bypassing the switch. The unit should then power up and function correctly ( Temporarily ) Hope this helps.
6/16/2018 5:40:23 PM • Haier HPRB07XC7... • Answered on Jun 16, 2018
HAIER ONly blows air on one side
Possible that the vent or the vane is blocked which can also be due to a jammed motor in the auto oscillation vent. Remove the panle and check the free movement which will confirm this case. Sometimes it could be dirt that is logged in that prevents free movement.
7/3/2012 5:11:13 AM • Haier HPRB07XC7... • Answered on Jul 03, 2012
0answers
No remote
Be the first to answer 6/20/2012 8:54:49 PM • Haier HPRB07XC7... • Posted on Jun 20, 2012Be the first to answer
Haier CWH24A. It isn't heating now that it's back on Heat mode
Question edited for clarity and add maker. Try a reset. Disconnect mains power for at least 2 hours. Reconnect and wait 5 minutes before turning on. This resets the mainboard and initiates a self test procedure. https://www.google.com/search?q=+Haier+CWH24A+not+heating+up ..
11/5/2023 9:53:52 PM • Haier Heating &... • Answered on Nov 05, 2023
Please my Haier Thermocool Ac automatically sets to 26c when I set it to 16 or any other number. It decreases slowly to 24 and stays there. Please what can be the cause of this? I need answers.
You will be able to get the answers from Haier support in your country. We are Fixya, not them. It sounds like a control board fault. You can try a reset. Turn it off at the breaker for 2 hours. Switch it back on and wait 5 minutes before turning the unit back on with the remote. https://www.google.com/search?q=Haier+Thermocool+AC ..
9/18/2023 6:30:27 PM • Haier Heating &... • Answered on Sep 18, 2023
Haier mini split E7 and exterior fan not working
On a Haier Split system a E7 error is a failure of the outdoor inverter PCB and the outdoor power supply PCB. Both will need replacing. Looking around $600 for those parts. Plus fitting. The indoor PCB is very unlikely to be needed.
11/8/2022 6:04:59 AM • Haier Heating &... • Answered on Nov 08, 2022
2answers
Remote for haier split- ac hsu-18dx"?
Window ac
9/20/2022 5:13:07 AM • Haier Heating &... • Answered on Sep 20, 2022
2answers
How do you add freon to haier window unit air conditioner
Window units do not come with service ports. You can buy them at local parts houses, but unless you have the freon, not gonna do you any good. Window ac use either r22 our 410a, and that cannot be bout without being certified.
8/7/2022 5:21:47 AM • Haier Heating &... • Answered on Aug 07, 2022
Haier air conditioner fan turns off when compressor is off
switch fro auto to cool function.
7/21/2022 6:20:08 AM • Haier Heating &... • Answered on Jul 21, 2022
2answers
Haier portable AC keeps displaying FL error code, even after i empty the water bucket, WHY?
Having the same issue, it's a shame the only answer is telling you to do what you clearly said you had already tried.
6/23/2022 11:48:02 PM • Haier Heating &... • Answered on Jun 23, 2022
2answers
Brand new portable AC. AC compressor comes on but doesn't seem to be cooling for long
Take it back and get another one. Once you try to work on it, void the warranty.
6/9/2022 12:17:02 PM • Haier Heating &... • Answered on Jun 09, 2022
We have a wall mounted Hair air conditioning unit
This is a communication error between the indoor and out door units.
2/21/2022 5:21:30 AM • Haier Heating &... • Answered on Feb 21, 2022
Haier HPRB07XC7 Portable Air Conditioner Logo
11 questions posted
Top Haier Heating & Cooling Experts
Paul Carew
Arnie Burke
Arnie Burke
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Haier Heating & Cooling
Most Popular Question
alarm light haier hprb07xc7 portable air
  • Heating & Cooling
