20 Most Recent Fisher and Paykel SMARTLOAD DE62TG1 Electric Dryer Questions & Answers
look on coolblueworld.com or paperwork for error code is in back consol . please unplug dryer if you remove consol.
Fisher and... | Answered on Mar 22, 2015
bad motor the safety switch in it is bad closed all the time
Fisher and... | Answered on May 04, 2014
clean your venting out
Fisher and... | Answered on Sep 19, 2013
if it sounds grindy while its running it may be a tub wheel is bad that the tub rides on take off the front and look
Fisher and... | Answered on Jan 16, 2013
It will open. You will need to just keep working it.
Fisher and... | Answered on Nov 11, 2012
1) Integrad circuit, for regulator voltage can be faulty, you must replace, the must have output for +5Vdc, for the display circuit.
sincerely. God bless you
Fisher and... | Answered on Jun 09, 2012
Hi ducktalk61...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me thumbs up
Fisher and... | Answered on Sep 11, 2011
No, is the dryer drum spinning? If not, replace the drum belt. If the drum is spinning but not drying the colths. The dryer heating elements is burnt out and needs to be replaced. GB..stewbison
Fisher and... | Answered on Aug 31, 2011
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Fisher and... | Answered on Jul 14, 2011
Turn on your dryer and tests your heater element.. see you have 240v going to it... if you do and no
heat you have a bad heater element
Fisher and... | Answered on Mar 25, 2011
I would guess thermal fuse:
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
here is another good website:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Good Luck Tim
Fisher and... | Answered on Mar 11, 2011
The link below is to a video that explains how to access the resettable fuse on the heater canister.
http://www.appliancerepairlesson.com/
Fisher and... | Answered on Mar 06, 2011
Fisher and Paykel SMARTLOAD DE62TG1 Electric Dryer Logo
45 questions posted
Top Fisher and Paykel Dryers Experts
Nathan Van Boven
Nathan Van Boven
Bill Eager
Dennis Boxerman
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
View Most Popular
  • Fisher and Paykel Dryers
Most Popular Question
fisher paykel dryer won 39 t heat dry
  • Dryers
