20 Most Recent Bosch Nexxt 500 Dryer Questions & Answers
needs a heat element
Bosch Nexxt 500... • Answered on Aug 05, 2018
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Bosch Nexxt 500... • Answered on Mar 21, 2017
Yes, this is a problem for our Nexxt dryer as well. This may work for you. I took an old garden hose, cut about three feet off it, then took a cap from spray paint can, cut a hole in it the diameter of garden hose. Put the hose in the cap. The spray paint cap fits nicely on my shop vac. Took the shop vac in the laundry room and attached the spray cap with the garden hose inserted and vacuumed the lint from the slot using the end of the garden hose. Worked pretty well. If you don't have a shop vac you may be able to stick a flexible hose in the end of you home vac and hold it with your hand to seal it. That should be able to remove most of the lint. Good luck.
Bosch Nexxt 500... • Answered on Dec 02, 2016
If I remember correctly there is a thermal cutout fuse that you can reset If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Bosch Nexxt 500... • Answered on Jun 07, 2016
Dear Judi, Using an electric meter, begin checking the various thermostats and the fuse for continuity. Also, check the heater coils. In all cases, remove the wires from the part before checking it, and be certain to remember from whence you took teach wire. You should find one of the the thermostats, or the fuse, or the heating element is "open" and needs replacement. God bless your effort.
Bosch Nexxt 500... • Answered on Jan 12, 2016
then u definately have a problem,and would be better getting a tech to look at it for u
CONSIDER THIS BOTH LEGS OF AC MUST WORK TO GET HEAT FOR DRYER Maybe you don''t have power to both legs of your receptacle. Both legs of the 220 volt AC have to work go get heat. Only one leg is used to run the motor etc.. Your motor runs so this can fool you into believing that the electrical connection is ok when it really is not. Your dryer is on a double circuit with two breakers. If one fails you lose one 110 volt leg which can be the one giving the full 220 Volt needed for the heater. This happens quite frequently and people mistakenly replace heating coils. You could have a bad breaker, one of the two. You must check this first before assuming anything else. Get help if you are uncomfortable with potentially deadly voltages
Bosch Nexxt 500... • Answered on Dec 15, 2015
Most Bosh dryer have a high limit sensor inside. Very easy to fix. disconnect power, remove back cover. there is lots of screws. usually torx head. you will see at the bottom of the dryer from the back side that there is 2 wires going to a round black "snap disk". there will be a bottom in the middle push the button in. if this dose not fix your problem you should get a in to fix it.
Bosch Nexxt 500... • Answered on Dec 11, 2015
usually located on the blower near the heater
Bosch Nexxt 500... • Answered on Mar 09, 2015
Sounds like a bad thermal fuse or thermostat, check all of them with a multi meter for continuity. as for the heater going out I would check ur venting inside and out the machine. the fuses and heater blow out for a reason? Usually due to overheating issues? I suspect ur lint build up is the problem?
First, turn off the breaker then back on. It should be a two poled breaker that is connected by a bar. Chances are this is where the problems lies. If not there, inspect the wiring from the outlet to the back of the dryer. The wires could have burned iOS come loose. This is retry basic since you have done all the hard work. Let me know if this gets it and we will pursue further.
Bosch Nexxt 500... • Answered on Feb 06, 2015
There are brushes that run through the exhaust like a chimney sweep, You can also do that by hand. What ever you do, there will be a lot of loose stuff left in the pipe; so don't clean the outside vent until last.
Bosch Nexxt 500... • Answered on Oct 13, 2014
Bosch Nexxt 500 Dryer Logo
307 questions posted
Top Bosch Dryers Experts
Lawrence Oravetz
Vernon Taylor
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
View Most Popular
Bosch Dryers
  • Bosch Dryers
Most Popular Question
e01 error message got all lint out
  • Dryers
