20 Most Recent
General Electric DRSR483GG Dryer Questions & Answers
There is a felt strip
Yes it is replaceable . Screws up into top from door opening 2 or 4. 2 screws into front from inside case into front . Lift up and out . Felt fits in groove around bottom of plastic frame and drum just rubs against it .
DRYER GENERAL ELECTRIC SUPER CAPACITY. APPARENTLY
A leading cause of poor drying results in that type of dryer is lint build up in the blower/lint filter housing. That build up will restrict air flow through the dryer causing very long dry times. To repair that the front panel would need to be removed and clean all the lint build up from that housing and blower wheel area.
To remove the front panel DISCONNECT POWER TO THE DRYER, on the bottom of the dryer inside of the door rim will be 2 phillips headed screws,remove those and lift off the top. At the top corners where the front panel connects to the cabinet will be 2 more phillips headed screws remove those and the front panel will pull off and out of the way. With the front panel off the blower housing will be in the lower left side clean lint from it and also the sure to clean all the lint from the lint filter housing which will be attached to the back side of the front panel. In addation to cleaning that area be sure to check and clean the exhaust duct tube as well.
GENE
Gsw schematic
Check the belt switch has a good contact through it
Amana Electric Dryer
You lucked out there but better replace that start switch because it will do it again just when you don't want it tol
Felt front gasket torn
Your local appliance parts store will have a felt gasket kit with all you need to repair it. If you aren't handy, you may want to call a technician.
