20 Most Recent Bosch PGL985UC 36 in. Gas Cooktop Questions & Answers
The burners light, but it
Need a new fsd ( looks like a small brass pencil) for the burner that won't light. The alignment of the ignition electrodes needs looking at and there over all condition I. E broken , worn , misaligned ect
3/13/2014 11:39:09 PM • Bosch PGL985UC... • Answered on Mar 13, 2014
I have bosch pgl985uc burner problem. The center burner will not stay lit. Seems other have had this problem. I ordered all new thermo-couplers. Installed, since Bosch changed them to a new part nu
If The Burner lights and stays lit as long as the knob is depressed, but goes out after the knob is released then there is a failure with the thermocoupler or the valve itself. The thermocoupler can be tested once removed from the cooktop - as follows Heat the tip on the thermocoupler with a match or lighter and measure the electrical connection (other end) with a voltmeter - it should read about 15 mV or slightly more with in a few seconds. If no voltage is read then the thermocoupler is faulty and should be replaced. The valve coil can also be tested for continuity at while the unit is disassembled. If no continuity is found the valve is faulty and should be replaced The small voltage created from heating the thermocoupler energizes the coil in the valve which in turn keeps the gas turned on while there is heat at the thermocoupler. Some units actually reignite the burner if the heat is lost and the control knob is in the on position. Hope this helps ....
1/4/2014 2:39:43 AM • Bosch PGL985UC... • Answered on Jan 04, 2014
Igniter stays on on the center and back right
If there is a relay it could possibly be sticking.
10/14/2013 1:53:01 AM • Bosch PGL985UC... • Answered on Oct 14, 2013
I have the same problem especially with the center burner, but now am having increasing difficulty with two other burners. Those will eventually stay lit if I depress the knob for 20 - 30 seconds. The center burner will not stay lit, even when keeping the knob depressed for 2 - 3 minutes!
7/14/2011 7:59:14 PM • Bosch PGL985UC... • Answered on Jul 14, 2011
Can't find replacement burner knobs for my
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
3/21/2011 7:42:32 PM • Bosch PGL985UC... • Answered on Mar 21, 2011
Where can I buy the gas valve and switch for the big middle
You can find parts for your unit by doing a search for “appliance parts”.
Once you get the results of the search, pick a site and when it comes up it will usually ask for the model number of your unit.
Enter your model number and you will then get a page with exploded views and a parts menu.
Find the part you need and then order it.
Check a few different sites to be sure that you are getting the best pricing.
Most sites can have the part to you in a couple of days.
Heatman101
1/12/2010 11:11:04 PM • Bosch PGL985UC... • Answered on Jan 12, 2010
I am looking for the part number for the LP
612938 Nozzle set liquid gas
9/19/2009 8:44:32 PM • Bosch PGL985UC... • Answered on Sep 19, 2009
Bosch induction not working
Very specialised high tech tops need engineers to fix. It is likely to be the power board. https://www.google.com/search?q=Schott+Ceran+stove+top+with+5+induction+hobs+no+power ..
12/9/2023 7:11:31 PM • Bosch Cooktops • Answered on Dec 09, 2023
Bosch oven display does not work at all but the cooktop works. what is the problem?
There could be a few different reasons why the display on your Bosch oven is not working, but the cooktop is functioning properly. Some possible causes include:
  1. A problem with the control panel: The control panel is responsible for controlling the oven and displaying information on the screen. If there is a problem with the control panel, it may be preventing the display from functioning properly.
  2. An issue with the oven's electrical system: If there is a problem with the oven's electrical system, it could be causing the display to malfunction. This could be due to a problem with the wiring, a faulty component, or a power issue.
  3. A problem with the display itself: It is also possible that there is a problem with the display itself, such as a damaged screen or a malfunctioning component.
In order to determine the cause of the problem and fix it, you will likely need to have the oven inspected by a professional appliance repair technician. They will be able to diagnose the issue and recommend the appropriate course of action.
1/6/2023 11:01:32 PM • Bosch Cooktops • Answered on Jan 06, 2023
Bosch Induction cooktop#NIT8665UC error code 3d or d3 at burner indicator
Did you ever get an answer to this? Same problem :(
7/27/2021 10:11:29 PM • Bosch Cooktops • Answered on Jul 27, 2021
2answers
Bosch induction cook top flashing F 9 snd will not work
https://www.fixya.com/support/t27212586-f9_code_flashing_bosch_induction_cook
1/24/2021 6:24:32 PM • Bosch Cooktops • Answered on Jan 24, 2021
Bosch PGL985UC 36 in. Gas Cooktop Logo
16 questions posted
Top Bosch Cooktops Experts
Paul Carew
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Bosch Cooktops
  • Bosch Cooktops
Most Popular Question
igniter stays center back right
  • Cooktops
