20 Most Recent
Agfa DC-1030S Digital Camera Questions & Answers
Lost soft wear need the drivers to upload photos Agfa 1030s
Hi Sandra:Sometimes the drivers isn't necessary to connect the digital cameras at pc; one method that I suggest is removing SD Card of the camera and use a
card reader. Allways this is so fast than connecting the camera directly at pc.Using the Explorer OS (Operative System) this device will appear as a external or removable
drive, then you will can use to copy/paste
pictures from the cardto the new folder in the pc.Check here about Card Readers:-
http://www.tigerdirect.com/Id=2827&name=External-
http://www.amazon.com/b?ie=UTF8&node=516872Hope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.Thank you for using Fixya, and have a nice day.
Where can i download a usb dc 1030s driver
Consider NOT using a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
WHAT Sd Card is used in the Agfa DC1003S camera?
You may use any SD card, up to 2GB in size. You may also use any SDHC card, up to 32GB in size. A faster card may download faster if you use a card reader but will not affect the operation of the camera. Any of the major brands will work.
I swapped memory cards with
The first mistake happened when your card was tried in your daughter's camera. She should have immediately formatted it first since the card was optimized for your camera's operating system. Since she didn't do that and tried to use it in her camera, the card became corrupted with two conflicting systems. Then, you put it back into your camera and didn't format it and it corrupted your camera.. So now, what do you do? Well, if your camera turns on, go into the menu and find "reset" to return to factory default settings. Then, if you want to use that card, the first thing you do is go into the menu and find "format" and follow the on-screen instructions. This will completely erase the card so if you have any pics on it that you want to save, you must download them first using a separate card reader.
It keeps turning off when i turn it on?
if you have confirmed the battery and still the set is turning off , then there is a fault within the camera electronics. it could be a jammed lens cover drive or a failure of the main board.
this will require expert review as the camera needs to be opend out to probe within the board for tracing the fault.
Recheck your battery volt/ amp rating once again. Good day
Ive got a agfa dc-1030 digital camera,and got a
Did you ever format the card in the camera before you tried to use it? This is necessary to optimize the card for the camera. This will erase the card so download any pics first using a card reader if necessary.
