20 Most Recent
Ricoh Aficio SG 3100SNw - multifunction printer / copier / scanner Questions & Answers
Sc 285 sur un photocopieur ricoh
You either have a torn ITB belt or a faulty ITB belt unit.
If this is not your problem then you could have a faulty ID sensor or a faulty PCU that is causing your Process Controll to fail and generate the SC285.
How can I fix a malfunctioning Ricoh 3410 printer?
On this page see error code 542.
Error Codes > Ricoh > SP3410DN > page 2 (printcopy.info)
- Code: 542
- Description: Fuser reload error
This SC is issued if one of following conditions occurs: The fusing temperature rises 8°C or less in 1.5 seconds; and this continues 5 times consecutively. -or- The fusing temperature has not reached 45°C within 9 seconds (after the fusing lamp comes ON while the machine is warming-up). -or- The fusing unit does not attain reload temperature within 35 s. (normal temperature) or 65 s (lower temperature - the thermistor output is less than 18°C) after the fusing temperature control starts.
I changed the developer and drum unit on my ricoh 2001sp but it prints faint
Several possibilities. Here are steps to take. First, shake the toner cartridge of this laser printer. Distribution of the toner could be the problem. Secondly, the problem might be a dirty Corona wire. That charges the toner so it sticks to the paper. Clean it by turning off the printer and unplugging it. Open the front cover and take out the toner cartridge. Locate the green tab at the top of the drum. Slide it back and forth several times. Return the tab to its original position. Reinstall the toner cartridge and close the cover. Plug it back in and test it out. Lastly, the problem might be the drum unit. Sadly, the fix for that is to replace the drum unit. Oops, I forgot to mention to check the settings to see what quality of printing they are set to. Good luck.
