20 Most Recent
Kyocera Ecosys FS-6525MFP Laser Multifunction Printer - Monochrome - P Questions & Answers
Toner on the back of copy
unit dumping toner or developer. usually caused by using non OEM supplies. have unit cleaned and use kyocera supplies
Trouble shooting with a finisher failure prompt?
I know this sounds as dunb as the stand tech support "restart you computer" junk but really try a FULL uninstall of the drivers. Run the uninstall remove directories, etc. and then re-install the drivers with the previous version you used. It fixed problem that made my HP 1020 not print for over a month which make no sense because I know that cause was a corrupt printer buffer from an aborted printout.
What is code Kyocera 3212i error code C3800
The error code C3800 on a Kyocera 3212i printer indicates an AFE error. This error occurs when writing data and reading data does not match 3 times continuously, or there is no response from AFE for 100ms. The following steps can be taken to resolve this issue:
Check the connection FFC is not connected properly. Or it is faulty. Clean the FFC terminals of the following FFC and reconnect them.
If the issue persists, consider contacting a Kyocera technician or service provider for further assistance.
Kyocera Printer wont scan
Check Network Connection: Ensure both devices are on the same network.
Restart Devices: Power cycle both computer and printer.
Verify Scanner Settings: Confirm correct scanner selection.
Update Drivers: Install latest printer drivers.
Firmware Update: Consider updating printer firmware.
Inspect Cables: Check all connections.
Contact Kyocera Support: If issue persists, reach out to Kyocera's support.
