20 Most Recent
Kyocera FS-4200DN Laser Printer - FS4200DN Questions & Answers
TK3122 chip reset
the devices are runup and intialised with geniune toner , fitting aftermarket toner and resetting chip, will only contaminate the developer in the dev unit, and cause all sorts of issues.
12/5/2014 8:54:14 AM •
Kyocera...
Answered
on Dec 05, 2014
What is code Kyocera 3212i error code C3800
The error code C3800 on a Kyocera 3212i printer indicates an AFE error. This error occurs when writing data and reading data does not match 3 times continuously, or there is no response from AFE for 100ms. The following steps can be taken to resolve this issue:
Check the connection FFC is not connected properly. Or it is faulty. Clean the FFC terminals of the following FFC and reconnect them.
If the issue persists, consider contacting a Kyocera technician or service provider for further assistance.
Kyocera Printer wont scan
Check Network Connection: Ensure both devices are on the same network.
Restart Devices: Power cycle both computer and printer.
Verify Scanner Settings: Confirm correct scanner selection.
Update Drivers: Install latest printer drivers.
Firmware Update: Consider updating printer firmware.
Inspect Cables: Check all connections.
Contact Kyocera Support: If issue persists, reach out to Kyocera's support.
