20 Most Recent
Tropical Oasis Sponge Gourd Luffa Loofa Cylindrica Bulk 100 Seeds Questions & Answers
How to repaint an iron fence?
Hiya,
When your painting iron its all about the primer, this helps its withstand the elements. Make sure you
also remove any existing rust! Here is a good example of how to paint a iron fence. Let me know if you have any questions
Home Fencing
Answered
on Aug 25, 2020
I am having trouble with my Elite CSW-200-UL gate on my driveway. It has randomly been responding to the remotes and then I had to punch in the code to make it work. Now it is not responding.
The first place to look is your receiver. This is the device, often separate from the actual gate operator, that responds to your transmitter. Stand next to the gate operator and you should hear a small click coming from the receiver when you or someone else pushes the button.
You can sometimes find the receiver by following the antenna cable back to it. If it does not have an external antenna, look inside the operator box for either an antenna screwed into the receiver or a wire hanging from a plastic box.
If you hear the click and the gate does not open, the possibilities grow exponentially so we won't try to address every possibility here. If you hear a click when you are close, but not when the transmitter is triggered at a distance, check the antenna.
If you don't hear the click, then either the remote has lost programming (this often happens with rolling codes transmitters when they are not used for a long time), or the receiver is not working.
Check to make sure the receiver is getting plenty of power power using a meter. It should read at the recommended voltage or a bit higher. Usually around 24 volts but some receivers can work down to 12 volts. If it gets plenty of power and the remotes have been programmed back in, consider replacing the receiver.
Home Fencing
Answered
on Mar 08, 2019
Tip
How to install a fence?
These days' people are becoming very much self-dependent, and as a result, they do a lot of things by themselves. One such thing that people do quite commonly these days is fencing. They love to install their own fences, but it is important that you do it the right way. You must also be aware of when you should and shouldn't put up a fence. This will prevent you from facing legal consequences. Getting back to the point, 5 simple steps are involved in installing a fence. The first step is to determine the poles for fence posts. You have to be careful when you are placing the post. Make sure you have dug the holes deep enough to avoid accidents. Then attach rails to the fence post and the last step is to
install the fence boards. You can also take a look at to know more information.
on Mar 19, 2018 | Home Fencing
