20 Most Recent Atlas KOMATSU Reconditioned Forklift - 2 Stage with Side Shift, 6000-lb Questions & Answers
recommended pressure should be on tire
Atlas KOMATSU... | Answered on Aug 28, 2017
Use your computer search engine, type in "Bolens 47018 owner's manual " it will bring up sites to get manual.
Heavy Machinery | Answered on Sep 25, 2020
87 or 88 Missing phase Check plug and 1A1 connections
87 Faulty TA Check phase on 55 and 51 and then 55A and 50
87 or 88 "c" axis beyond 210 degrees Reset hex shaft
88 Emergency switch depressed Release emergency switch
88 Faulty "c" axis encoder Check control card connections, check encoder star wheel for damage and tightness. Clean with air if dirty
https://ercolina-usa.com/wp-content/uploads/2012/03/050-Top-Bender-Classic-Manual-02-2018.pdf
Heavy Machinery | Answered on Sep 15, 2020
Since you have already removed the rivets, just go to the numbered portion of the instructions below and follow them to replace the rope.
To put the recoil assembly back on the blower housing, you will need to obtain a pop rivet tool and rivets or or 4 very short machine screws with lock washers and nuts and insert them from inside the blower housing so the flywheel doesn't hit the ends, and tighten them securely
Here is the instructions DIRECT FROM BRIGGS & STRATTON:
This is a relatively simple process, but you have to be VERY careful when doing this. The spring is long, under some tension and has sharp edges. Anytime you are dealing with the manual rewind starter assembly, there is risk of the spring coming out and possibly injuring yourself or others. If you do not feel comfortable performing this repair, I strongly suggest visiting one of our many authorized dealers in your area and have them do this for you.
You will have to remove the gas tank to get at the rewind and blower housing. Remove the entire blower housing and rewind assembly and turn it upside down.
NOTE:You do not have to drill out the rivets to get to the back of the rewind assembly. This is only necessary if you are removing the ENTIRE rewind assembly, (metal housing and all) and are separating it from the blower housing.
You'll need a pair of vise grips or a screw driver, some rewind rope, a long thin sharp tip flexible object (the wire from a coat hanger may work) and a lighter handy.
  1. Take the pulley and start to turn it so that the rope becomes loose.
  2. Remove the rope.
  3. Once the pulley is all the way out, with the most tension, either use the screwdriver between the spokes of the pulley, or use the vise grips to hold the pulley in place; be careful not to place too much pressure on the vise grips, the plastic pulley may break!
  4. Make sure that the hole in the pulley lines up with the hole on the rewind assembly.
  5. Using the wire from the coat hanger, push the rope through the hole of the rewind and pulley. Pull the rope through the pulley and tie it off. Now use the lighter to burn the end of the rope to prevent the not from coming off.
  6. Now, remove the screwdriver or vise grips, while holding on to the pulley.
  7. SLOWLY let go of the pulley and the rope should feed back into the pulley as you do this.
Heavy Machinery | Answered on Apr 12, 2020
there is a solenoide problem.
in the right side of the front engine under the alternater has an oil pump and on top of that is a solenoid. after some time the build dirt and grease on the connector.\
that should be it.\
Heavy Machinery | Answered on Mar 18, 2020
https://www.youtube.com/watch?v=7DTxB9v6Nv8
Heavy Machinery | Answered on Feb 17, 2020
For all kind of manuals. You can also visit this website.They offer 100% satisfaction guarantee.
https://big-manuals.com/
Heavy Machinery | Answered on Jan 11, 2020
Contact John Deere to request
Heavy Machinery | Answered on Dec 27, 2019
Contact John Deere directly to request the diagram.
Heavy Machinery | Answered on Dec 24, 2019
check the pressure for each of the clutch packs through the test ports with a pressure gauge, sounds like you are losing pressure when the oil is hot and thin. Have the engine at running temp when testing,
also test the charge pump pressure for system pressure.
Heavy Machinery | Answered on Dec 17, 2019
Model 256c means it's a Caterpillar. Did you look under the seat? Since you apparently don't have an owner's manual, you need to get one. Manual should be stored on the machine in a weatherproof case.
Disconnecting all electric+hydrolic+cooling and the engine is taken out through rear door
Heavy Machinery | Answered on Oct 23, 2019
Atlas KOMATSU Reconditioned Forklift - 2 Stage with Side Shift, 6000-lb Logo
3 questions posted
Top Atlas Heavy Machinery Experts
Bill Boyd
JonSnell Electronic
JonSnell Electronic
Derrick Schultz
Derrick Schultz
Are you an Atlas Heavy Machinery Expert? Answer questions, earn points and help others
View Most Popular
  • Atlas Heavy Machinery
Most Popular Question
tire pressure komatsu fg25 8
  • Heavy Machinery
