20 Most Recent RTO Ho Herpa Freightliner Truck Tractor Questions & Answers
on 2006 freightliner century with 12.7 detroit 60 Error code
eng contreller no resp. 128s254 07.
RTO Ho Herpa... | Answered on Jun 11, 2020
A check engine light and fault 61 code is an electrical failure to the injector or a bad solenoid on the injector, but you will most likely find your problem at the terminal crimp.
RTO Ho Herpa... | Answered on Jan 07, 2020
I have a 2010 freightliner with the code:f8fcff - spn: 523512 FMI: 31
RTO Ho Herpa... | Answered on Jun 21, 2019
1.1/4 inch preferably 1 inch drive and at 135 lbs foot lbs most of the nuts have torque settings stamped on them.
RTO Ho Herpa... | Answered on Sep 27, 2018
internal ram motor computer
RTO Ho Herpa... | Answered on May 26, 2018
Snoop old mate , only you will know that by your regular repayments for loans
just ask your finance operation ( bank etc) for a credit reference
RTO Ho Herpa... | Answered on Mar 07, 2016
it is a slim chanch of it being ur data link sounds to me like the x-y shifter has gone out should be able to hook up pro link and get the code have had to replace many of these shifters that has done the same thing hope this helps J & R Truck & equip repair
RTO Ho Herpa... | Answered on Sep 24, 2015
Are you sure that is the code? Its engine "128", but the rest isnt adding up.
Here are the all the C15 engine codes.http://world-engine-blog.blogspot.com/2013/09/c13-c15-and-c18-engines-diagnostic_23.html ENGINES AND MORE
RTO Ho Herpa... | Answered on Apr 29, 2015
I've been told to never put stop-leak in anything.
Best bet is to have a mechanic find the leak and repair it.
Could be only a loose fill or drain plug.
Hope this helps.
RTO Ho Herpa... | Answered on Mar 27, 2015
I don't know that much about trucks, but I would see if all the brakes are releasing, you may have a set or two sticking.
RTO Ho Herpa... | Answered on Sep 20, 2014
Fault in the compressed air line or generator or connection valves for the break lines.
RTO Ho Herpa... | Answered on Sep 19, 2014
If you have access to a multimeter check at the cig lighter plug and see if it has power. The center of the socket is HOT side and the side of socket is ground. It maybe just the plug itself had gone bad. You can get them at Autozone or any auto parts store. Cut the old one off and put the new on on paying attention to which wire is the hot. Usually the wire will have a marking to identify the ground wire, or if it will be black wire & red wire. Red wire will be hot side. If the icebox is portable try plugging it into another vehicle. You could also run temporary wire to it from the battery to see if it works.
RTO Ho Herpa... | Answered on Aug 27, 2014
Check driveshaft and rear axle alignment. Measure center of front axle to center of rear axle on each side of the truck it should be the same distance. Check ride height if air ride equipped from the bottom of the air bag to the bottom of the frame rail should be roughly 12 to 13 inch
RTO Ho Herpa... | Answered on Aug 04, 2014
RTO Ho Herpa Freightliner Truck Tractor Logo
159 questions posted
Top RTO Toys Experts
Marvin
Marvin
ray gallant
Bill Boyd
Are you a RTO Toy Expert? Answer questions, earn points and help others
View Most Popular
RTO Toys
  • RTO Toys
Most Popular Question
2005 freightliner century will not turn
  • Toys
