20 Most Recent
Farmall IH Tractor 460, 560, 660, 2606 ITIH25 Questions & Answers
Is hydraulic fluid really used for both the
caseih hytran fluid is used for hydraulics and transmission fill through plate on top of deck next to shifter check plug is located on left side of transmission housing next to clutch linkage rod probably square headed pipe plug
I have a 59 farmall
Turn Counter clockwise to loosen for more slack. You need about .005 to .008" slack if to tight you will break your new cylinder.
What kind of hydraulic fluid can i use in my
universal hydraulic fluid is all we use it is used for the transmission and the hydraulics, about 25 bucks for 2.5 gallons, put in at the gear shift until it comes out plug below cluch pedal. Check any cenex gas station .
I have a propane Farmall
if it's like my 560 the firing order is as follows going clockwise from the #1 on your distributor is 142635 #1 should be marked on distributor cap for #1
