20 Most Recent Morton Salt Inc 15010000 - Water Softener Salt, System Saver II, 50lb Questions & Answers
Probably need to clean the vortex / venturi. If you have iron in your water, you need to clean this about every 6-12 months, depending on how many ppm your water has).
It's an simple & easy procedure. First remove the cover of the softener (usually held on by 2 clips in front, 2 in back).
Once the cover is off, on the left side of the valve you will see a conical-shaped plastic part. (Usually gray, but not always). You will need to unscrew this (it's ok if water is still on, it's not under any pressure unless it's recharging) and clean the screen inside.
Most likely the screen will be caked with iron oxide (rust). I use a rust dissolver (such as Iron Out or any product designed to dissolve rust, but this is strong stuff, wear gloves or wash you hands immediately afterwards) and let the screen soak in that for 1/2 hour. If needed, you can speed the process along by using an old toothbrush and clean the screen, then soak a little longer, brush again, etc.
Once clean, replace the screen (mind the O-ring) and cover (hand tight is sufficient). Start a manual regeneration and clean the resin bed.
-If you decide to remove the rest of the parts in the vortex/venturi, be very careful not to lose anything. A few of these parts are very small. There should be a diagram of how the parts go together in your owners manual and on the machine itself. Usually these will not need cleaning, but doesn't hurt to go ahead and make certain. As to the two rubber parts with holes in them, the one with the larger hole goes on the bottom, and on both, the rounded side goes up. Watch carefully when you disassemble and remember so you can reassemble in the correct order with done.
As you have water in the brine tank (salt tank) keep an eye on this to prevent a salt bridge from forming. This is more prevalent with rock salt than pellets, but can form with any salt.
(I would strongly recommend you never use "rock salt" in any softener. It's full of dirt and you will absolutely need to clean out the brine tank at least annually or the dirt will end up being drawn into the softener. I use a good quality of salt pellets with an "red out" to maintain the resin against iron. These are usually good up to 2 ppm iron, anything over this and you should use a 1/2 box of Iron Out or similar, every 6 months).
If you suspect a salt bridge has formed, try pouring hot water onto the salt at one spot. This will dissolve the salt in that spot and form a "hole" in the salt. (Hot water dissolves salt faster than cold).
Once you break through, use a broom handle to break the salt surrounding the hole and it will collapse into the bottom of the brine tank. Suspect a salt bridge is the machine runs properly, but no soft water.
She probably does NOT need to replace this unit. What you perceived as a leak may only be water backing up in the brine tank and leaking out of the overflow.
Morton Salt Inc... | Answered on May 17, 2016
A water distiller is a device that removes most impurities from water, through distillation. Distillation means boiling the water and then collecting the condensed steam into a clean container.
Water Dispensing... | Answered on Mar 15, 2020
It may be time to replace the light or the Light ballast.
To reset the CHANGE FILTER indicator light, press and hold the LOCK and LIGHTkeypads until the CHANGE FILTER light blinks (approximately 3 seconds). The control for the light is now reset for another 12 months or 416 gallons of use.
Water Dispensing... | Answered on Sep 13, 2019
It screws on to the tank. Make sure to relieve water psi. Turn the water off first.
It is common for it to have high PH after replacing filters. It will adjust after the first 15 to 20 gallons. When I replace filters 10.8ppm to 11.2ppm is normal. After so many gallons I read 9.6ppm https://www.freedrinkingwater.com/faq.htm
Water Dispensing... | Answered on Apr 02, 2019
Morton Salt Inc 15010000 - Water Softener Salt, System Saver II, 50lb Logo
1 questions posted
Top Morton Salt Inc Water Dispensing & Filtration Experts
Tom Chichester
Rolly North
Level 1 Expert
Larry
Are you a Morton Salt Inc Water Dispensing and Filtration Expert? Answer questions, earn points and help others
View Most Popular
  • Morton Salt Inc Water Dispensing & Filtration
Most Popular Question
daughters water softener filled up water
  • Water Dispensing & Filtration
