20 Most Recent Dictaphone 2740 Desktop Cassette Transcriber / Recorder Questions & Answers
0answers
Best dictaphone for conference Recording
Hello the Dictaphone 2740 does not have the option for telephone record or conference recording you need the Model that is really similar to the 2740 the model is 2750 this model has telephone record option and conference record capable.
Note: for telephone record you need to buy a separate adaptor like this ECS-DPRC
10/30/2011 8:01:39 PM • Dictaphone 2740... • Answered on Oct 30, 2011
Can I wipe off (erase)
Hello Just press an hold Erase and Rew Keys.
3/12/2011 10:07:29 PM • Dictaphone 2740... • Answered on Mar 12, 2011
I have a Dictaphone Desktop Voice Processor Model
It's possible the play capstan belt is broken - or the main capstan motor is stalled.
9/1/2010 4:36:49 PM • Dictaphone 2740... • Answered on Sep 01, 2010
Is there a repair center in the san fernando, ca.
Hello I recommend this place is close to San Fernando
Executive Communication Systems
1445 Donlon Street Suite 1 Ventura, CA 93003 United States or Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
6/26/2010 7:56:36 PM • Dictaphone 2740... • Answered on Jun 26, 2010
Wont play cassette
Usually when this happens it is either the "Pinch Rollers" or the "Drive" motor, has failed. You need to get it looked at.
4/29/2010 1:32:54 AM • Dictaphone 2740... • Answered on Apr 29, 2010
Just put in my first tape for the 2740. Even SLOW
Hello this transcriber is only a 4.8 Speed transcriber and the slide speed control is on the front of the unit if the cassette that you are trying is a Normal 4.8 speed and is not responding you need to send your unit for service you can try this place Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
4/3/2010 4:26:55 AM • Dictaphone 2740... • Answered on Apr 03, 2010
Need manual for a used Dictaphone 2720
I tried searching for a free manual to download, but I could not find one. I can give you a link, but the manual is for sale. Please check the link below:
http://www.tvps.com/Products/Dictaphone-2720-Manual---Standard-Cassette-Dictator-Transcriber-Desktop__ECS-MANDI2720.aspx
I do apologize. I wanted to provide you a free manual, but this is what I've found.
Good luck and have a great day!
2/14/2010 10:28:12 PM • Dictaphone 2740... • Answered on Feb 14, 2010
How do i erase a tape on the Dictaphone 2740
Hello Just Press and Hold the erase button located on the bottom rigth then press rewind. All the rewind part will be erase.
2/12/2010 12:30:32 AM • Dictaphone 2740... • Answered on Feb 12, 2010
NECESITO DIAGRAMA PARA DICTAPHONE 2750 DESKTOP
Hola en realidad no tengo el diagrama pero you te recomiendo que verifique la tableta pricipal por la parte posterior normal mente es muy comun una de las venas del trasistor se fracture observe cuidadosa mente por la fractura ya que si no te equivocaste al conectar el motor no creo que este danado el trasistor recuerda que el Modelo 2740 su motor es de 4 terminales la primera de lado izquierdo es negativo despues positivo sige A y despues B qae estos dos ultimos son para resitencia de velocidad variable 20K
1/7/2010 5:09:24 AM • Dictaphone 2740... • Answered on Jan 07, 2010
Dictaphone MicWiz
Catherine, did you ever get an answer for your problem with MicWiz? I am a transcriptionist that works from home and they are having problems getting it to recognize my foot pedal (as well as another MT) with the new software. It is recognized by Express Scribe and ever other system we use, but not Merge.
Thank you, Cindy
12/15/2009 9:30:07 PM • Dictaphone 2740... • Answered on Dec 15, 2009
2answers
Is there any fixing with this problem of model
your unit has a broken cam gear you need to sen it to repair here are a place
12/12/2009 4:03:51 AM • Dictaphone 2740... • Answered on Dec 12, 2009
Dictaphone ExpressWriter system - tape will not rewind, play, ff
Is this a standard-size cassette unit? Is the model number a 2740 or 2750? When you first plug the power in, does the machine make two clicking noises? Does the display show 'CAS' or 'No Cassette'?
7/27/2009 7:59:41 PM • Dictaphone 2740... • Answered on Jul 27, 2009
Dictaphone Expresswriter 2740 Tape Won't Move
The problem is with the capstan motor. More than likely it has developed a 'flat spot' and won't spin up. The clicking noise you hear is the solenoids trying to pull the heads into place, but because the motor isn't turning, it can't pull the heads into place.
3/13/2009 4:46:37 AM • Dictaphone 2740... • Answered on Mar 13, 2009
Dictaphone 2740 Desktop Cassette Transcriber / Recorder Logo
31 questions posted
Top Dictaphone Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Dictaphone Audio Players & Recorders
Most Popular Question
get earphones dictaphone model 2470
  • Audio Players & Recorders
