20 Most Recent Galt Folding Trampoline Questions & Answers
Hi ajrother...
Amazon provides many products, so take a look there. This one can help you Upper Bounce Replacement Elastic Bungee Cords for Trampoline Jumping Mats... (If fits of course).
Also you can contact the seller if helps. Hope this was helpful. enjoy
Galt Folding... | Answered on Nov 19, 2014
37b2c1d3-7d38-4344-8a02-dd0a8d14e6fc.gifFind the manual... But here's an image of it if that helps.
Galt Folding... | Answered on May 27, 2013
no, it's not safe. have a local repair shop see if they can reattach spring before using.
Galt Folding... | Answered on Feb 13, 2011
Galt was acquired by Elmer's Products. I was able to reach the company re. a new bungee for the trampoline by calling the following. They were very helpful.
For product or ordering information about GALT™ toys in the United States, please call 1.800.931.2218, or email [email protected]
Galt Folding... | Answered on Feb 04, 2011
Did you check the metal pin and spring terminals the batteries sit between? If a battery powered toy is stored with the batteries still in the terminals can corrode and block the electrical current from the batteries. Try cleaning the terminals with a cotton bud and Very Fine sand paper. A cardboard nail file works well for this.
Toys | Answered 16 hours ago
how long are your arms??
Toys | Answered Yesterday
Reference: Paisley Electronic Push Code Safe
Item # 5661462
Purchased at Justice. May be one of the following design/colors: 1. Pink and black 2. neon green 3. tye-dye (all in zebra pattern, I believe)
To gain access to safe without code proceed with the following simple instructions:
Use a screw driver to access batteries on the bottom of the safe. Remove all three AA batteries.
WAIT AT LEAST TEN SECONDS before reinserting betteries to functional position. Replace screw. Key in default passcode "0000#" Safe will now be unlocked and upon opening you can reset passcode. Hold down the "*" and when voice prompted to "key in passcode" enter new 4 digit code followed by the # sign... HOLD "*" until completed code with "#" You will hear the voice command, "enter passcode" after each digit entered. [Press & hold "*" (1234) press "#" release "*"] Close safe and new passcode should be set and work properly. If not, enter default "0000#" and try to reset once again.
Toys | Answered 3 days ago
Disconnect the electrical connector that joins the arches. Unscrew the half of the arch that holds the batteries. Check the red lead from the battery compartment. Mine had two problems - it was almost disconnected from the battery, and had another disconnect in the middle. Twist the wires together at both fault points and tape (electrical tape) or solder. I soldered and my Learning Home is now working perfectly.
--gdipersio
Toys | Answered on Nov 16, 2020
There are tutorials and video's on YouTube and on Goggle then on how to make your own decorations for birthdays and for Christmas and Easter and Halloween and for Valentines day too.
Toys | Answered on Nov 11, 2020
Put the crank handle in the down position and then use the arrows on the gears to guide you. The two gears that hold the two spirals should be closest to you. Make the two arrows on the gears point directly at each other(keeping the crank in the down position). The third gear's arrow (furthest from you) should point directly at you bisecting an imaginary line formed by the other two arrows pointing at each other. The idea is to get the spirals lined up so they create a channel for a ball to fit in.
Toys | Answered on Oct 04, 2020
https://directbrown.weebly.com/dreamsky-alarm-clock-radio-user-manual-ds201.html#dreamsky-alarm-clock-radio-user-manual-ds201
Toys | Answered on Sep 29, 2020
Maybe you can search on Amazon or Ebay. This manual is cetainly on sale.
Toys | Answered on Aug 28, 2020
Galt Folding Trampoline Logo
12 questions posted
Top Galt Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Galt Toy Expert? Answer questions, earn points and help others
View Most Popular
Galt Toys
  • Galt Toys
Most Popular Question
trampoline bungee broke need buy
  • Toys
