20 Most Recent Vtech Fly and Learn Globe Questions & Answers
Is this a new problem, has the unit worked in the past? You may need to reset the unit - remove the batteries for a few minutes, then re-insert. You may also try new batteries.
This is a link to the product manual: http://www.vtechkids.com/_f/_pw/_manual/Fly_and_Learn_Globe.pdf
Vtech Fly and... | Answered on Oct 15, 2010
Hi there, there doesn't seem to be any specific information online for how to take it apart, but I've attached the user manual as a link to reverse the process. It seems you can easily remove the "shoulders" from the "base", all four legs can be detached easily, and the stool has removable legs as well.
Hope this helped.
Vtech Toys | Answered on Apr 18, 2020
Apparently you can disconnect all power supplies (batteries and adapter), then reconnect all power supplies. Press the ON/OFF button. Remove the storybook cartridge, clean it if necessary, then re-insert it into the V.Reader.
I've also included the product manual as a link.
There doesn't seem to be any real answers online for this, but if you're out of options, I'd contact their customer service team at https://www.vtechkids.ca/en/support/form or call 1-877-352-8697.
Hey there, seems like you've already tried many solutions.
May I suggest checking if the SD card has been formatted before its first use (check to see if your SD card is formatted as a FAT16 or FAT32 partition). I have attached a link with further details on doing this.
Also make sure your SD card is not in write-protected mode (the Lock switch on your SD card should be in the off position) and try again.
As well, make sure you have the most updated software on your device.
If nothing else works, I got the below text from the Vtech website.
"If you have a problem that cannot be solved by using this manual, we encourage you to visit us online or contact our Consumer Services Department with any problems and/or suggestions that you might have. A support representative will be happy to assist you. Before requesting support, please be ready to provide or include the information below:
• The name of your product or model number (the model number is typically located on the back or bottom of your product). • The actual problem you are experiencing.
• The actions you took right before the problem occurred.
Internet : www.vtechkids.com
Phone : 1-800-521-2010 in the U.S. or 1-877-352-8697 in Canada"
Go to settings and it should have something about Languages and press that and press english.
Vtech Toys | Answered on Jan 29, 2019
Go to the settings under MY NAME and type in R-E-S-E-T to erase everything and start over. That is the only way to remove a name!!
Vtech Toys | Answered on Aug 24, 2017
Vtech Fly and Learn Globe Logo
3 questions posted
Top Vtech Toys Experts
ThaMp3Doctor
ThaMp3Doctor
Geoff
Marvin
Marvin
Are you a Vtech Toy Expert? Answer questions, earn points and help others
View Most Popular
Vtech Toys
  • Vtech Toys
Most Popular Question
lost instructions
  • Toys
